Assembly within assembly Detection
I would like to see if there is a routine that allows my iLogic code to detect if my assembly contains another assembly within it. If my assebly contains assemblies then I don't want "MyRule" to run. Else if it does then I want "MyRule" to run.
Write a function that returns a boolean.
in the function loop through the top level document's referencedDocuments property.
If any end in ".iam" stop looping and return a true.other wise return a false.
If you need to check part files as well then you will need to check each part files referencedDocuments Count property.  If it is > 0 then return true otherwise false.
jdkriek
Something like this:
Dim oDoc As Document = ThisDoc.Document
Dim oRefDoc As Document
Dim AsmFound As Boolean
For Each oRefDoc In oDoc.AllReferencedDocuments
	If oRefDoc.DocumentType = kAssemblyDocumentObject Then
		AsmFound = True
		Exit For
	End If
Next
If AsmFound = False Then
	iLogicVb.RunRule("MyRule")
End If
Jonathan D. Kriek
MFG Solutions Engineer
KETIV Technologies, Inc.
Actually Jonathon He only needs to check the references under the top level, not the all the referenced in his assembly.  That is why I suggested ReferencedDocument instead of AllReferencedDocuments.
Just as you are using an If..Exit in your loop when there is no point in continuing further.
Thanks that worked out great
