Assembly: Promote subcomponent in a hidden document
mirkomaga
mirkomaga
I have tried to promote the subcomponent of an assembly component.
It works if I open the visible document, but if it is hidden it doesn't.
Is there a reason?
Stakin
before end sub
add
oDoc.Update
oDoc.Close
See agian
mirkomaga
mhh, add(?)
Error is before.
Stakin
post your code in txt
mirkomaga
Yes sorry
Sub test()
        Dim s As String
        s = "pathiam"
        ' Get the active assembly document
        Dim oDoc As AssemblyDocument
        Set oDoc = ThisApplication.Documents.Open(s, False)
        Dim oDef As AssemblyComponentDefinition
        Set oDef = oDoc.ComponentDefinition
        ' Get the top level occurrence of an assembly
        Dim oSubAssyOcc As ComponentOccurrence
        Set oSubAssyOcc = oDef.Occurrences.Item(1)
        ' Get the 2nd level occurrence under the assembly occurrence
        Dim oSubOcc As ComponentOccurrenceProxy
        Set oSubOcc = oDef.Occurrences.Item(1).SubOccurrences.Item(1)
        Dim oPane As BrowserPane
        Set oPane = oDoc.BrowserPanes.Item("Model")
        ' Get the browser nodes corresponding to the two occurrences
        Dim oTargetNode As BrowserNode
        Set oTargetNode = oPane.GetBrowserNodeFromObject(oSubAssyOcc)
        Dim oSourceNode As BrowserNode
        Set oSourceNode = oPane.GetBrowserNodeFromObject(oSubOcc)
        ' Reorder the nodes to promote the sub-occurrence to the top level
        Call oPane.Reorder(oTargetNode, True, oSourceNode)
End Sub
