You should be able to set up your color selection in the Subroutine I have set up [with top level assembly and a single Occurrence]. I don't change the color of Occurrences with iLogic, so I'm not sure of the best way to set that portion up. Here is a bit of code I threw together:
Sub Main
'External Rule Lockout
If ThisApplication.ActiveDocumentType <> kAssemblyDocumentObject Then MessageBox.Show("This rule is designed to only work in assembly documents.", "Wrong Document Type") : Exit Sub
'User Selection Setup, can be done other ways
Dim ocList As New List(Of String)
For Each oc As ComponentOccurrence In ThisApplication.ActiveDocument.ComponentDefinition.Occurrences
If oc.DefinitionDocumentType = DocumentTypeEnum.kAssemblyDocumentObject Then ocList.Add(oc.Name)
Next
Dim Selection As String = InputListBox("", ocList, ocList.Item(0), Title := "Item to Remove", ListName := "Sub Assemblies")
If IsNothing(Selection) Then Exit Sub 'No selection made
'After Occurrence is selected. "Selection" string can be manually set or set by a list and some logic to choose.
Dim selOcc As ComponentOccurrence = ThisApplication.ActiveDocument.ComponentDefinition.Occurrences.ItemByName(Selection)
'Verify selected occurrence is part of a pattern
If selOcc.IsPatternElement
Dim Col As ObjectCollection = FindParticipants(selOcc)
For Each oOcc As ComponentOccurrence In Col
Call ColorSetting(ThisApplication.ActiveDocument, oOcc)
Next
Else
If MessageBox.Show("The Selected Occurrence: " & selOcc.Name & " is not part of a Pattern. Would you like to Set Color for this Occurrence Individually?", "Single Occurrence", MessageBoxButtons.YesNo) = vbYes Then Call ColorSetting(ThisApplication.ActiveDocument, selOcc)
End If
End Sub
Function FindParticipants(Oc As ComponentOccurrence) As ObjectCollection
Dim Result As ObjectCollection = ThisApplication.TransientObjects.CreateObjectCollection
Dim level1 As OccurrencePattern = Oc.PatternElement.Parent
LoopHere :
For Each Element In level1.OccurrencePatternElements
For Each Occ In Element.Occurrences
Result.Add(Occ)
Next
Next
'Dig through further patterns if initial pattern is an element
If level1.IsPatternElement
level1 = level1.PatternElement.Parent
GoTo LoopHere
End If
Return Result
End Function
Sub ColorSetting(parent As AssemblyDocument, Oc As ComponentOccurrence)
MessageBox.Show(Oc.Name, "Testing")
'Setup your case selection here
End Sub
The selection process can be modified, I just threw a list selection in there for now.
