Assembly Create with custom sheet metal template causes delayed crash
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Using the Assemble Create under the Component tab then selecting my sheet metal template causes an eventual crash. The sheet metal part will be created and inserted into the assembly. I can sometimes close the new part, update and save the assembly before the crash. After the part edit is done, I have 20 seconds or so before the crash. I am using the assembly to create an non adaptive sheet metal part. Using a non sheet metal part to do this does not cause a crash. I started a new test assembly and still get the crash if I use my sheet metal template. I have not seen this behavior until I added the "STRECH_OUT_RULE" rule and variables to report to custom iproperties. The forum and "SheetMetalRule" did not cause this error on there own. Before or now I haven't seen other problems with parts made with this template. I assume its my "STRECH_OUT_RULE" ilogic but there is no crash report. I could use some help troubleshooting this. I have the latest update of Inventor installed.
