- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I work as engineer for a company that makes electric motors.
There are alot of combinations possible creating electric motors (flanges, sizes, shafts).
I have recieved all variant parts of these motors as 3D file, instead of manually adding them thogether for every request i want to make an automated Inventor model. I am trying to make a proof of concept for this.
A motor model always consists of 5 parts;
- Front Flange
- Rear shield
- Body
- Connection box
- Shaft
I thought of using i-mates combined with i-logic to add the parts into an assembly, however i can't get it work properly;
For some reason the flange, body & rear shield are placed correctly. But the shaft and connection box aren't.
I triple checked the i-mates on the shaft, which are only 2 mates, i just don't understand why it get's placed incorrectly....
I added the files for generating 1 simple motor.
The code i use i pretty plane so far;
Dim oDoc As AssemblyDocument = ThisDoc.Document
Dim oACD As AssemblyComponentDefinition = oDoc.ComponentDefinition
Dim oParts(0 To 4) As String
oParts(0) = "DN71-B"
oParts(1) = "DN71-C"
oParts(2) = "DN71-A-F120"
oParts(3)= "DN71-F"
oParts(4)= "DN71-E"
For Each item In oParts
oACD.Occurrences.AddUsingiMates("C:\Data\Werkmap\animatie\K met ratio\" & item & ".ipt", False)
InventorVb.DocumentUpdate()
Next
Thanks in advance 🙂
