[Approach Needed] - How to re-orient step files
aelqabbany
aelqabbany
I have a large number of step files that contain extruded parts which were drawn in random orientations. My objective is to get the extrusion direction to be in parallel to the Z-axis, then re-export those files as step files.
I can get the camera to face the "profile face" of the part through the code below, but I can't think of a way to set the XY plane to be parallel to the camera front.
Sub Main()
	oPartDoc = ThisApplication.ActiveDocument
	getLargestAreaFace(oPartDoc)
	oCamera = ThisApplication.ActiveView.Camera
	oCamera.ViewOrientationType = ViewOrientationTypeEnum.kRightViewOrientation
	oCamera.ApplyWithoutTransition
	ThisApplication.ActiveView.SetCurrentAsFront
End Sub
Function getLargestAreaFace(oPartDoc As PartDocument) As Face
    Dim maxarea As Double: maxarea = 0
    Dim oFace As Face
    Dim ofacemax As Face
    For Each oFace In oPartDoc.ComponentDefinition.SurfaceBodies.Item(1).Faces
        If oFace.SurfaceType <> kCylinderSurface Then
            If oFace.Evaluator.Area > maxarea Then
                maxarea = oFace.Evaluator.Area
                ofacemax = oFace
    Next
	Dim oSSet As SelectSet
	oSSet = oPartDoc.SelectSet
	Call oSSet.Clear
	Call oSSet.Select(ofacemax)
	ThisApplication.CommandManager.ControlDefinitions.Item("AppLookAtCmd").Execute2(True)
End Function
The result:
The other approach I was thinking of is to create a new assembly, import the part, align the longest edge of the largest face to the Z-axis, then export the assembly as a step file.
I am open to any suggestions.
Thanks in advance.
Michael.Navara
Bad news:
You are not able to redefine origin (base planes and axes).
You are not able to move existing body (without creating some transform features).
Good news:
You can copy existing body to the new position and hide the original body.
Then you can export STEP file with visible bodies only.
Here is code sample how to do it. It creates copy of selected body and sets the orientation. You can choose from three different implementations.
  • Fixed (precalculated) transformation
  • Transformation defined by active view
  • Transformation defined by planar face (face normal defines z axis) and linear edge (edge direction defines x axis)
Source body becomes invisible.
Final body is not moved to first quadrant and origin can be everywhere. If it is important for you, you need to modify the code.
Sub main
	Dim partDoc As PartDocument = ThisDoc.Document
	'Select body for transformation
	Dim srcBody As SurfaceBody = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kPartBodyFilter, "Select body")
	'Setup transformation
	'Select from following implementations
	Dim t As Matrix
'	t = GetTransformationFixed()
'	t = GetTransformationFromActiveView()
	t = GetTransformationFromPlaneAndEdge()
	'Copy source body
	Dim tgtBody = ThisApplication.TransientBRep.Copy(srcBody)
	'Transform body to position
	ThisApplication.TransientBRep.Transform(tgtBody, t)
	Dim entities = ThisApplication.TransientObjects.CreateObjectCollection
	entities.Add(tgtBody)
	'Create NonParametricBaseFeatureDefinition
	Dim baseFeatureDef As NonParametricBaseFeatureDefinition = partDoc.ComponentDefinition.Features.NonParametricBaseFeatures.CreateDefinition()
	baseFeatureDef.BRepEntities = entities
	baseFeatureDef.OutputType = BaseFeatureOutputTypeEnum.kSolidOutputType
	partDoc.ComponentDefinition.Features.NonParametricBaseFeatures.AddByDefinition(baseFeatureDef)
	'Hide source body
	srcBody.Visible = False
	SetFinalCamera()
End Sub
Function GetTransformationFixed() As Matrix
	'Setup body transformation
	Dim tg = ThisApplication.TransientGeometry
	Dim o As Point = tg.CreatePoint(1, 2, 3)
	Dim x As Vector = tg.CreateVector(1, 1, 0)
	x.Normalize()
	Dim y As Vector = tg.CreateVector(-1, 1, 0)
	y.Normalize()
	Dim z As Vector = tg.CreateVector(0, 0, 1)
	z.Normalize()
	Dim t As Matrix = tg.CreateMatrix()
	t.SetCoordinateSystem(o, x, y, z)
	Return t
End Function
Function GetTransformationFromPlaneAndEdge() As Matrix
	Dim face As Face = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kPartFacePlanarFilter, "Select top face")
	Dim plane As Plane = face.Geometry
	Dim n As UnitVector = plane.Normal
	Dim edge As Edge = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kPartEdgeLinearFilter, "Select X edge")
	Dim line As LineSegment = edge.Geometry
	Dim d As UnitVector = line.Direction
	Dim o = face.PointOnFace
	Dim x = d.AsVector
	Dim z = n.AsVector
	Dim y = z.CrossProduct(x)
	y.Normalize
	Dim t As Matrix = ThisApplication.TransientGeometry.CreateMatrix()
	t.Invert()
	Return t
End Function
Function GetTransformationFromActiveView() As Matrix
	Break
	Dim cam As Camera = ThisDoc.Document.Views(1).Camera
	Dim z = cam.Target.VectorTo(cam.Eye)
	z.Normalize
	Dim y = cam.UpVector.AsVector()
	Dim x = y.CrossProduct(z)
	x.Normalize
	Dim o = cam.Target
	o = ThisApplication.TransientGeometry.CreatePoint()
	t.Invert
	Return t
End Function
Sub SetFinalCamera
	cam.Target = tg.CreatePoint(0, 0, 0)
	cam.Eye = tg.CreatePoint(0, 0, 1)
	cam.UpVector = tg.CreateUnitVector(0, 1, 0)
	cam.ApplyWithoutTransition
End Sub
Ralf_Krieg
Hello
I think you can not find the front face as largest face. This will work only in a few situations. I think you manually need to select the correct face.
Cause I've already wrote the code, i post it as alternative.
Sub Main()
    Dim oPartDoc As PartDocument= ThisApplication.ActiveDocument
    Dim oTrans As Transaction = ThisApplication.TransactionManager.StartTransaction(oPartDoc, "OrientSolid")
	Try
		'Dim oFaceMax As Face = getLargestAreaFace(oPartDoc)
		Dim oFaceMax As Face = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kPartFaceFilter,"Select a face")
	    Dim oSSet As SelectSet= oPartDoc.SelectSet
	    Call oSSet.Clear
	    Call oSSet.Select(oFaceMax)
	    ThisApplication.CommandManager.ControlDefinitions.Item("AppLookAtCmd").Execute2 (True)
	    Call oSSet.Clear
	    Call OrientSolid(oPartDoc)
	    Dim oWorkPlane As WorkPlane
	    For Each oWorkPlane In oPartDoc.ComponentDefinition.WorkPlanes
	        If Left(oWorkPlane.Name, 2) = "XY" Then Exit For
	    Next
	    Call oSSet.Select(oWorkPlane)
	    ThisApplication.ActiveView.Fit
	Catch
		oTrans.Abort
	Finally
		oTrans.End
	End Try
End Sub
Private Sub OrientSolid(ByVal oPartDoc As PartDocument)
	Dim oApp As Inventor.Application = ThisApplication
	Dim oSB As SurfaceBody = oPartDoc.ComponentDefinition.SurfaceBodies(1)
	Dim oTransBRep As TransientBRep = oApp.TransientBRep
	Dim oTransUnion As SurfaceBody= oTransBRep.Copy(oSB)
	Dim oAddBody As SurfaceBody
	Dim oTransAdd As SurfaceBody
	If oPartDoc.ComponentDefinition.SurfaceBodies.Count > 1 Then
	    Dim i As Integer
	    For i = 2 To oPartDoc.ComponentDefinition.SurfaceBodies.Count
	        oAddBody = oPartDoc.ComponentDefinition.SurfaceBodies(i)
	        oTransAdd = oTransBRep.Copy(oAddBody)
	        Call oTransBRep.DoBoolean(oTransUnion, oTransAdd, kBooleanTypeUnion)
	    Next
	Dim oCamera As Camera= ThisApplication.ActiveView.Camera
	Dim oMatrix As Matrix = oCamera.WorldToView
	Call oTransBRep.Transform(oTransUnion, oMatrix)
	Dim NonParaDef As NonParametricBaseFeatureDefinition= oPartDoc.ComponentDefinition.Features.NonParametricBaseFeatures.CreateDefinition
	Dim oBodyColl As ObjectCollection = oApp.TransientObjects.CreateObjectCollection
	Call oBodyColl.Add(oTransUnion)
	NonParaDef.BRepEntities = oBodyColl
	NonParaDef.OutputType = BaseFeatureOutputTypeEnum.kSolidOutputType
	NonParaDef.DeleteOriginal=True
	Dim NonParamBaseFeat As NonParametricBaseFeature= oPartDoc.ComponentDefinition.Features.NonParametricBaseFeatures.AddByDefinition(NonParaDef)
	NonParamBaseFeat.Name = "Rotated_Solid"
	For Each oFeature As Object In oPartDoc.ComponentDefinition.Features
	    If Not oFeature.name = "Rotated_Solid" Then oFeature.delete
	Next
End Sub
R. Krieg
RKW Solutions
www.rkw-solutions.com
aelqabbany
Thank you both very much. I will test both approaches next week, God willing.
