Apprentice in VBA
Apprentice in VBA
Andy73
Apprentice in VBA
Andy73
I know it sounds strange but, I am trying to use apprentice in Inventor VBA. Many of the objects work just fine. I would like to set a FileSaveAs object to an ApprenticeServerComponent.FileSaveAs. I can get the ApprenticeServerComponent but some of the objects are in an error state. Is there any way to connect to these objects in VBA?
Thank You
Andy
The use of Apprentice within VBA is not supported. Apprentice cannot be run
in process with Inventor.
Sanjay-
Andy73
Sanjay;
Would "in process with Inventor" include as an Addin?
Andy
Yes, Add-ins typically run in-process with Inventor. It's possible to create
out-of-process Add-ins, but I've never seen them being used. All the SDK
Add-in samples run in-process with Inventor.
Sanjay-
Sanjay,
Does that mean that it is possible to use Apprentice objects within e.g. Excel VBA code that is running out-of-process with Inventor? Do you see any limitations in this case?
ALink
Yes, that's possible. No limitations there as far as I know.
Sanjay-
