apprentice change display name / browser name
pawel.gromanski
pawel.gromanski
I'm trying to change iproperties and display/browser name of part or assembly (the one showing in model browser) using apprentice. Iproperties working fine but I can't change display name. Here's my code:
Dim apprentice As Inventor.ApprenticeServerComponent
apprentice = New Inventor.ApprenticeServerComponent
Dim apprenticeDoc As Inventor.ApprenticeServerDocument = Nothing
apprenticeDoc = apprentice.Open(FILE)
apprenticeDoc.PropertySets.Item("Inventor Summary Information").Item("Subject").Value = "value1"
apprenticeDoc.PropertySets.Item("Design Tracking Properties").Item("Part Number").Value = "value2"
apprenticeDoc.PropertySets.FlushToFile()
apprenticeDoc.DisplayName = "value3"
Dim oFileSaveAs As FileSaveAs
oFileSaveAs = apprentice.FileSaveAs
oFileSaveAs.AddFileToSave(apprenticeDoc, apprenticeDoc.FullFileName)
oFileSaveAs.ExecuteSave()
WCrihfield
Just a quick question...can you 'read' that DisplayName's value OK from Apprentice?  I know that DisplayName is normally Read/Write when accessed from Inventor, but I haven't tried changing that before from Apprentice, so I'm just curious whether it may simply be one of the things that is ReadOnly when accessed from apprentice, for some reason.
Wesley Crihfield
(Not an Autodesk Employee)
pawel.gromanski
I tried reading display name. I can read original value then change it and read new value, I guess problem is saving changes.
I tried oFileSaveAs.ExecuteSaveCopyAs and I got new file with changed iproperties but display name was still the same.
pawel.gromanski
Has anyone successfully changed and saved display name with apprentice? API help says it's Get/set value.
