Apply a sheet metal rule to multiple parts at once
reine_den_andra
Message 1 of 16
reine_den_andra
Is there a way to apply a sheet metal rule to multiple parts at once?
I get 100's of STEP files that don't have a sheet metal rule on them, and therefore can't make a flat pattern.
What I do today is to open each part for itself, put a sheet metal rule on it, and then be able to make a flat patten on it. That takes some time....
Accepted solutions (3)
Replies (15)
Message 2 of 16
hollypapp65
Add Sheet Metal rule to ipt Template then import again.
You also save Sheet Metal Rules to Style Library and use it in ipt that don't have Sheet Metal Rules.
You do need a Rule in Style Library first.  Then write program to copy it to other file.
Message 3 of 16
reine_den_andra
Thank you for the reply. The thing is, I dont know how to do rules at all. Its pure Greek to me, and I feel stupid.
Can you help me with this?
Message 4 of 16
hollypapp65
Message 5 of 16
reine_den_andra
Yes I know what sheet metal rules are, I have 30 of them. But I dont know how to apply a specific sheet metal rule to let´s say 20 "dead" parts at the same time.
Is that possible?
Message 6 of 16
jnowel
This is something i did in the past to batch change all the sheetmetal rule for all the components in an assy.
The sheetmetal rules need to be in the Standard (or all the part has it as a local sheetmetal rule)
You'll select a rule and that would affect ALL the sheetmetal components.
Give it a try and let me know if you encounter some issues
If Not TypeOf ThisApplication.ActiveDocument Is AssemblyDocument Then
	MessageBox.Show("Use this rule in an Assy only")
	Exit Sub
End If
Dim oADoc As AssemblyDocument = ThisApplication.ActiveDocument
Dim oOcc As ComponentOccurrence
Dim oPartDict As New Dictionary(Of String, String)
Dim oSMStyle As SheetMetalStyle = Nothing
For Each oOcc In oADoc.ComponentDefinition.Occurrences
	Dim oOccDoc As Document = oOcc.Definition.Document
	Dim oOccDocName As String = oOccDoc.FullDocumentName
	If Not oOccDoc.SubType = "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}" Then Continue For 'NOT SHEETMETAL
	If Not oPartDict.ContainsKey(oOccDocName) Then
		oPartDict.Add(oOccDocName, oOccDocName)
		Logger.Info(oOccDocName)
		Dim oPartDoc As PartDocument = oOccDoc
		Dim oPartCompDef As SheetMetalComponentDefinition = oPartDoc.ComponentDefinition
		Try: oPartCompDef.UseSheetMetalStyleThickness = True
		Catch : Logger.Info("ERROR in UseSheetMetalStyleThickness: " & oPartDoc.DisplayName)
		End Try
		Try : oPartCompDef.UseSheetMetalStyleUnfoldMethod = True
		Catch : Logger.Info("ERROR in UseSheetMetalStyleUnfoldMethod: " & oPartDoc.DisplayName)
		End Try
		Try : oPartCompDef.UseSheetMetalStyleMaterial = True
		Catch : Logger.Info("ERROR in UseSheetMetalStyleMaterial: " & oPartDoc.DisplayName)
		End Try
		Logger.Info("Active Rule: " & oPartCompDef.ActiveSheetMetalStyle.Name)
		If oSMStyle Is Nothing Then
			Dim oSMStyles As SheetMetalStyles = oPartCompDef.SheetMetalStyles
			Dim oSMStyleList As New List(Of String)
			For i = 1 To oPartCompDef.SheetMetalStyles.Count
				oSMStyleList.Add(oPartCompDef.SheetMetalStyles.Item(i).Name)
			Next i
			oSMStyleName = InputListBox("Select Sheetmetal Rule", oSMStyleList, oPartCompDef.SheetMetalStyles(1), Title := "Title", ListName := "List")
			Try
				oSMStyle = oPartCompDef.SheetMetalStyles.Item(oSMStyleName)
			Catch
				MessageBox.Show("No Style Selected, Exiting")
			End Try
			Logger.Info(oSMStyleName)
		End If
		Try
			oPartCompDef.SheetMetalStyles.Item(oSMStyleName).Activate
			Logger.Info("NEW Rule: " & oPartCompDef.ActiveSheetMetalStyle.Name)
		Catch :
			Logger.Info("ERROR: " & oPartDoc.DisplayName)
		End Try
		If Not oPartCompDef.HasFlatPattern Then
			oPartCompDef.Unfold
		End If
	End If
Next
Message 7 of 16
reine_den_andra
OH MY GOD !!! You made my day 100% better. THANK YOU! ❤️
This is as close as you can get to what I mean. Absolutely incredible! 😀
(The only thing that doesn't work is that the thickness doesn't change even though it says so when I open the detail.)
Edit: It works perfectly. I tried an old STEP export which is a bit incorrect.
I'm not very good at this with rules. What do you mean by: The sheetmetal rules need to be in the Standard.
Message 8 of 16
jnowel
I may have worded it poorly.
What I meant is that the SheetMetal Rule be saved in the Library (so every sheetmetal part can access that rule)
You can do that by "Save to Library", is still haven't.
I was (incorrectly) thinking it is the same as "Add to Standard" option when creating new Local style like in the drawing environment.
The iLogic rule above assumes that all sheetmetal parts has access to the Sheetmetal rule you want applied.
If the sheetmetal rule is unavailable, the iLogic rule will fail to activate/change to that chosen sheetmetal rule.
if you can enable your iLogic Log through
You can see the logs (as i included them in the ilogic rule) and a bit of what has happened.
as an example of what happens when the sheetmetal rule is unavailable in one of the parts:
say, i selected "Steel 5mm" but this is only a local style (to the first part, "TEST copy.ipt") and only available to that part only
the log will show the active rule before changing, which is "Steel 3mm" and it successfully change it to "Steel 5mm"
but for "TEST.ipt", it errors as it cannot change to the "Steel 5mm" (as it is unavailable)
as opposed to say changing it to "HDPE 10mm" that is saved in the Library and accessible to all sheetmetal
Both "TEST copy.ipt" and "TEST.ipt" has been successfully change to the new sheetmetal rule selected
Message 9 of 16
reine_den_andra
You are lika a god to me! Thank you for all this. I am soo happy right now!
I will click "Accept Solution" here.
Message 10 of 16
reine_den_andra
Hello
This works great. But is i possible to make this work with sub-assemblies?
	Exit Sub
End If
		End Try
		End Try
		End Try
			Next i
			Try
			Catch
			End Try
		End If
		Try
		Catch :
		End Try
			oPartCompDef.Unfold
		End If
	End If
Next
Message 11 of 16
Curtis_Waguespack
Hi @reine_den_andra, see this version of @jnowel's example that will traverse through subassemblies.
Hope that helps, Curtis
Sub Main
	If TypeOf ThisApplication.ActiveDocument Is PartDocument Then
		Call SMRules(ThisApplication.ActiveDocument)
		Exit Sub
	ElseIf TypeOf ThisApplication.ActiveDocument Is DrawingDocument Then
		MessageBox.Show("Rule can not be used in a drawing")
		Exit Sub
	End If
	Dim oOccs As ComponentOccurrences = oADoc.ComponentDefinition.Occurrences
	Call TraverseAssembly(oOccs)
End Sub
Function TraverseAssembly(oOccs As ComponentOccurrences)
For Each oOcc In oOccs
	If oOcc.Suppressed = True Then Continue For
	If oOcc.DefinitionDocumentType = DocumentTypeEnum.kAssemblyDocumentObject Then
	'step into subassembly
	Call TraverseAssembly(oOcc.SubOccurrences)
	Else 'process parts
	If Not oPartDict.ContainsKey(oOccDocName) Then oPartDict.Add(oOccDocName, oOccDocName)
	Call SMRules(oOccDoc)
	End If
Next
End Function
Sub SMRules(oOccDoc As PartDocument)
Try : oPartCompDef.UseSheetMetalStyleThickness = True
End Try
End Try
End Try
Next i
Try
Catch
End Try
End If
Try
Catch :
End Try
oPartCompDef.Unfold
End If
End Sub
Message 12 of 16
reine_den_andra
Thank you for reply! 😀
I will try this tomorrow at work. (Sweden 18:50 a clock) 😁
Message 13 of 16
reine_den_andra
Hi!
I have tested this now. It's a bit strange. The box about which sheet metal rule you want opens up for each detail. In this case, 50 times in an assembly with subassemblies and parts 😁.
Even if the SAME part is in multiple places.
In a perfect world, I would wish that the first code I posted, @jnowel´s could take subassemblies.
Message 14 of 16
jnowel
hmm. I think it might be better to just run thru all the referenced documents instead of relying on the component occurrence like in the original code.
Try the one below.
	Exit Sub
End If
For Each oRefDoc As Document In oADoc.AllReferencedDocuments
	If Not oRefDoc.SubType = "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}" Then Continue For 'NOT SHEETMETAL
	Dim oPartDoc As PartDocument = oRefDoc
		Next i
		Try
		Catch
		End Try
		Logger.Info(vbLf & "Selected Sheetmetal Style: " & oSMStyleName & vbLf)
	End If
	Logger.Info(oRefDoc.DisplayName)
	Catch : Logger.Info("     ERROR in UseSheetMetalStyleThickness: " & oPartDoc.DisplayName)
	End Try
	Catch : Logger.Info("    ERROR in UseSheetMetalStyleUnfoldMethod: " & oPartDoc.DisplayName)
	End Try
	Catch : Logger.Info("    ERROR in UseSheetMetalStyleMaterial: " & oPartDoc.DisplayName)
	End Try
	Logger.Info("     Active Rule: " & oPartCompDef.ActiveSheetMetalStyle.Name)
	Try
		Logger.Info("     NEW Rule: " & oPartCompDef.ActiveSheetMetalStyle.Name)
	Catch :
		Logger.Info("     ERROR: SM Style Missing/Not Applied")
	End Try
		oPartCompDef.Unfold
	End If
Next
(I also changed the logger info so it makes it easier to check the issues)
Message 15 of 16
reine_den_andra
Oh my god! 😀😀😀
You're absolutely amazing at this. This is so good I feel guilty.
How can I thank you?
Message 16 of 16
jnowel
all good. I'm still also learning as well here in the forums.😁
seeing other people's solutions give me ideas and perspective; and solving problems also help me practice
