- Mute
- Permalink
- Report
I'm looking at a way to edit the Application Options tab when a particular file is opened. For example, by loading file "template" it would set constraint options to a standard, set the background color of the application, etc. giving me a songle file to load my preferred settings.
For a first run example, could someone help me with code such that when I open the file and run the rule, it would change the username from User to NWilson?
I'm very weak with the API code tools and structure, and I have zero VB experience. My train of thought is as follows:
Dim x = ThisApplication.GeneralOptions.UserName
If x = User
Then ThisApplication.GeneralOptions.UserName=NWilson
Obviously, I don't know this language yet, so you're helping me learn syntax as well as solve this particular problem. A link to any resources on this language would be doubly appreciated.
Thanks.
