Application.FileManager.CopyFile or System.IO.File.Copy?
Skadborg.NTI
Skadborg.NTI
I only see two differences between Application.FileManager.CopyFile or System.IO.File.Copy - am I missing some?
1: System.IO.File.Copy handles any filetype, Application.FileManager.CopyFile handles only Inventor filetypes.
2: Application.FileManager.CopyFile has three different overwrite levels (kOverwriteExistingFile, kOverwriteReadOnlyFile and kOverwriteReservedFile). System.IO.File.Copy only has Overwrite true/false and can not overwrite a ReadOnly protected file.
Dev_rim
I always choice System.IO library. When designing anything for inventor I think it is important to leave application object to itself as much as possible. Also at some projects I am using external files to collect data like XML, Excel files, or images and icons etc.. So my project folders also can contain "non-Inventor" files. At the end its always better to use original Windows libraries.
If you want to overwrite read-only protected files, you can change the ReadOnly attribute of the file like one line of code 🙂
File.SetAttributes("C:\\myfile.txt", File.GetAttributes("C:\\myfile.txt") & ~FileAttributes.ReadOnly);
More detailed one:
var attr = File.GetAttributes(path);
// set read-only
attr = attr | FileAttributes.ReadOnly;
File.SetAttributes(path, attr);
// unset read-only
attr = attr & ~FileAttributes.ReadOnly;
At the end I think it's your choice, it depends what kind of projects you are working on, and your style for sure.
For me, if I can do anything using original Windows libraries, I prefer doing them using original Windows libraries.
Regards
Devrim
If my answer is solved your problem, please mark it as Solution
Freundliche Grüße / Kind Regards
