- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Is it possible to save an attribute to an appearance then save it to a library? I would like to store some finish data that can be accessed later from the api. I can apply the attribute to all the necessary renderstlyes and use the SaveToGlobal() method. It seems to work great in the part the program is run from, but when I go to the next part and apply the same appearance it does not contain the new attribute. I have also tried creating a copy of the appearance in the document then save that to the library, but any appearances that I edit or create programmatically will not save to the library even if manually drag it within the appearance editor. My project show the material and appearance libraries set to read/write and if I create an appearance thought the editor I can move it to the library without any problems, it's only the items created/modified through the api that will not move. I am running Inventor 2013 SP2. Any suggestions?
Andy
