Appearance color to specific face
markGlthen
markGlthen
I'm using Inventor 2020 and I would like to know how to apply a color to specific face using iLogic.
Face0 = Red
Face1 = Yellow
I tried to use "iProperties.PartColor", but this paint all faces.
robertast
Here at me I change the colors depending on the features
Sub main()
Dim partDoc As PartDocument = ThisDoc.Document
Dim namedEntities = iLogicVb.Automation.GetNamedEntities(partDoc)
Dim faceF As Face = namedEntities.FindEntity("Front")
Dim faceB As Face = namedEntities.FindEntity("Back")
Dim faceL As Face = namedEntities.FindEntity("Left")
Dim faceR As Face = namedEntities.FindEntity("Right")
Dim a As String = iProperties.Value("Custom", "Ak1")
Dim b As String = iProperties.Value("Custom", "Ak2")
Dim c As String = iProperties.Value("Custom", "Pk1")
Dim d As String = iProperties.Value("Custom", "Pk2")
If a = ""
faceF.Appearance = partDoc.AppearanceAssets("_oMDP")
Else
faceF.Appearance = partDoc.AppearanceAssets(iProperties.PartColor)
End If
If b = ""
faceB.Appearance = partDoc.AppearanceAssets("_oMDP")
Else
faceB.Appearance = partDoc.AppearanceAssets(iProperties.PartColor)
End If
If c = ""
faceL.Appearance = partDoc.AppearanceAssets("_oMDP")
Else
faceL.Appearance = partDoc.AppearanceAssets(iProperties.PartColor)
End If
If d = ""
faceR.Appearance = partDoc.AppearanceAssets("_oMDP")
Else
faceR.Appearance = partDoc.AppearanceAssets(iProperties.PartColor)
End If
iLogicVb.UpdateWhenDone = True
InventorVb.DocumentUpdate()
End Sub
markGlthen
@robertastthank you for replying.
I didn't understand why do you created a custom properties "Ak1, Ak2..." and what would "_oMDP" be?
I just want to color the "Face0" with red color, I tried it, but no worked.
Sub main()
Dim faceF As Face = namedEntities.FindEntity("Face0")
Dim a As String = iProperties.Value("Custom", "Red")
If a = ""
faceF.Appearance = partDoc.AppearanceAssets("Red")
Else
End If
End Sub
FINET_Laurent
I made up this code with bits from the forum.
It turns the desired face to a random color.
Can't find how to get a specific colors.
Dim oDoc As PartDocument = ThisDoc.Document
Dim namedEntities = iLogicVb.Automation.GetNamedEntities(oDoc)
Dim faceA As Face = namedEntities.FindEntity("Face0")
Dim uApprearence As Asset
uApprearence = oDoc.Assets.Add(kAssetTypeAppearance, "Generic", "appearances")
Dim uColor As ColorAssetValue
	  uColor = uApprearence.Item("generic_diffuse")
		RNG = Round(Rnd * 255)
		RNG1 = Round(Rnd * 255)
		RNG2 = Round(Rnd * 255)
        uColor.Value = ThisApplication.TransientObjects.CreateColor(RNG, RNG1, RNG2)
        faceA.Appearance = uApprearence
FINET L.
If this post solved your question, please kindly mark it as "Solution"
If this post helped out in any way to solve your question, please drop a "Like"
@LinkedIn     @JohnCockerill
moveworkforward
Please run this iLogic rule in the part document.
It will set Face1 appearance to "Light Red-Orange" and Face2 to "Smooth - Yellow".
Sub Main
	Dim assetName1 = "Light Red-Orange"
	Dim assetName2 = "Smooth - Yellow"
	Dim oPartDoc As PartDocument = ThisApplication.ActiveDocument
	Call CopyAssetToLocalDocument(assetName1,oPartDoc)
	Call CopyAssetToLocalDocument(assetName2,oPartDoc)
	oPartDoc.ComponentDefinition.SurfaceBodies(1).Faces(1).Appearance = oPartDoc.AppearanceAssets.Item(assetName1)
	oPartDoc.ComponentDefinition.SurfaceBodies(1).Faces(2).Appearance = oPartDoc.AppearanceAssets.Item(assetName2)
End Sub
Sub CopyAssetToLocalDocument(assetName As String,oPartDoc As PartDocument)
	Dim assetLib As Asset
	assetLib = ThisApplication.AssetLibraries.Item("Autodesk Appearance Library").AppearanceAssets(assetName)
	Dim oAsset As Asset
	Dim AssetIsFound As Boolean: AssetIsFound = False
	For Each oAsset In oPartDoc.AppearanceAssets
	    If oAsset.DisplayName = assetName Then
	        AssetIsFound = True
	        Exit For
	    End If
	Next
	If AssetIsFound = False Then
		oAsset = assetLib.CopyTo(oPartDoc)
	End If
End Sub
