The TextureMaps does not provide the property to change the texture orientation, you can use the appearance asset to change it, below is a VBA sample to do this, you can select a face in UI then run the code:
Sub RotateTextureOfAppearanceOnFace()
Dim oDoc As PartDocument
Set oDoc = ThisApplication.ActiveDocument
On Error Resume Next
' Select a Face from UI first.
Dim oFace As Face
Set oFace = oDoc.SelectSet(1)
If Err Then
MsgBox "Select a Face from UI first!"
Exit Sub
End If
Dim oAppearance As Asset
Set oAppearance = oFace.Appearance
Dim oNewAppearance As Asset
Set oNewAppearance = oAppearance.Duplicate
Dim oAssetValue As AssetValue
Dim oTextureAssetValue As TextureAssetValue
Dim oRotationValue As FloatAssetValue
Dim oAssetTexture As AssetTexture
' find a texture and rotate the texture by 90 degrees.
For Each oAssetValue In oNewAppearance
If oAssetValue.ValueType = kAssetValueTextureType Then
If InStr(1, LCase(oAssetValue.Name), "color") Then
Set oTextureAssetValue = oAssetValue
Set oRotationValue = oTextureAssetValue.Value("texture_WAngle") '(23) / Angle
oRotationValue.Value = 90 ' This should be a defect that the Double value is not in radians.
End If
ElseIf oAssetValue.ValueType = kAssetValueTypeColor Then
Dim oColorAssetValue As ColorAssetValue
Set oColorAssetValue = oAssetValue
If oColorAssetValue.HasConnectedTexture Then
Set oAssetTexture = oColorAssetValue.ConnectedTexture
Set oRotationValue = oAssetTexture.Item("texture_WAngle") '(23) / Angle
End If
End If
Next
' override the appearance
oFace.Appearance = oNewAppearance
End Sub
Hope this helps.
If this solves the problem please click ACCEPT SOLUTION so other people can find it easily.
Rocky Zhang
Inventor API PD
Manufacturing Solutions
Autodesk, Inc.
