API support\limits: convert Solid to a surface in a part
I try to convert Solid to a surface in a part, I only succeed to open the next windows automatically (Thicken/Offset) as you can see in the image,
But I could not select surface option, and then OK button.
This is how I open the window automatically (Thicken/Offset): Dim oControlDef As ControlDefinition = Form1.appMain.CommandManager.ControlDefinitions.Item("PartThickenOffsetCmd") oControlDef.Execute()
Sergio.D.Suárez
This is an ilogic rule that turns every face of a solid into a surface, maybe it can serve you.
Remember that you can export to iges to obtain brep surfaces.
Dim oPartDocument As Inventor.PartDocument
oPartDocument = ThisApplication.ActiveDocument
Dim oCompDef As Inventor.ComponentDefinition
oCompDef = oPartDocument.ComponentDefinition
Dim oSBodies As Inventor.SurfaceBodies
oSBodies = oCompDef.SurfaceBodies
Dim oSBody As Inventor.SurfaceBody
Dim oFace As Inventor.Face
Dim oThicken As ThickenFeature
For Each oSBody In oSBodies
    For Each oFace In oSBody.Faces
		Dim oFaceColl As FaceCollection
		oFaceColl = ThisApplication.TransientObjects.CreateFaceCollection
		oFaceColl.Add(oFace)
		oThicken = oCompDef.Features.ThickenFeatures.Add(oFaceColl, "0", PartFeatureExtentDirectionEnum.kNegativeExtentDirection, PartFeatureOperationEnum.kSurfaceOperation, False, False, False)
    Next
Next
 I hope it helps you solve your problem
Please accept as solution and give likes if applicable.
I am attaching my Upwork profile for specific queries.
Sergio Daniel Suarez
Mechanical Designer
| Upwork Profile | LinkedIn
Thanks!
