Api: set and attribute on DesignViewRepresentation object fails with Com-Exception
Holzethekid
Holzethekid
Hallo,
i am trying to set an attribute on a DesignViewRepresentation object.
here my code:
var v = representationsManager.DesignViewRepresentations[3];
v.AttributeSets.Add("21212");
but this fails with
System.Runtime.InteropServices.COMException: 'Unbekannter Fehler (Exception from HRESULT: 0x80004005 (E_FAIL))'
in the documentation DesignViewRepresentation.AttributeSets there is no infromation that it is not implemented.
Maybe any one know what i am doing wrong ?
thanks in advance
JhoelForshav
Hi @Holzethekid
I did some testing just now and came to the conclusion that the attribute set name is not allowed to start with a number 🙂
If you change it to for example:
v.AttributeSets.Add("a21212");
 then it should work.
