Adaptable iAssembly
Hi
Posting here because would be some code involved, or at least i will be intending to control it with code.
I have a space that can vary in length and top / bottom angle. The space will always be an equal value divisible by 400mm (already set up in the base model). What i need to figure out is the best way to populate the space with an iAssembly of components to follow the shape. Can an iAssembly be flexible or adaptable driven by imates? That would be the easiest way for sure. I can control the quantity, i just need to find the best way to populate the space. Here is a representation of the space
So, There are some dims i can provide. I can get the top / bottom angles, left right lengths so i 'could' pass them to an iAssembly with code and iMate it in place but is there a better easier more fluid way to do this?
Nacho
Automation & Design Engineer
Inventor automation Programmer (C#, VB.Net / iLogic)
Furniture, Sheet Metal, Structural, Metal fab, Tradeshow, Fabrication, CNC
