API: Push Parameter Value of "MainPart" to others
In the assembly, I would like to push the parameter value of the "MainPart" if the parameter exists in the other parts.
"MainPart" parameter conditions:  If it contains "x".
Other parts DisplayName conditions: If it contains "Include".
I hope my explaination is understandable.
In pure ilogic, it would be like this:
Parameter("Include_01:1", "x_Width") = Parameter("MainPart:1", "x_Width")
Parameter("Include_02:1", "x_Height")=Parameter("MainPart:1", "x_Height")
Here is the unfinished code that my brain can only do.
Dim oDoc As AssemblyDocument = ThisAssembly.Document
Dim asmDef = oDoc.ComponentDefinition
Dim oMainParam As New ArrayList
Dim i As Integer = 0
For Each occ As ComponentOccurrence In asmDef.Occurrences
	Dim occDoc As Document = occ.Definition.Document
	If occ.Name.Contains("Main") Then
		Dim oMain As PartDocument = occDoc
		MsgBox(oMain.DisplayName)
		For Each oParam In oMain.ComponentDefinition.Parameters
			If oParam.Name.Contains("x") Then
				oMainParam.Add(oParam.Name)
				'MsgBox(oMain.DisplayName & vblf & vblf & oParam.Name)
			End If
		Next
		For x As Integer = 0 To oMainParam.Count - 1
		xList = xList & vbLf & oMainParam(x) & vbLf
		Next
		MessageBox.Show(xList)
	End If
	If occDoc.DisplayName.Contains("Include") Then
	i += 1
	MsgBox(i)
	End If
Next
Thank you so much.
Ralf_Krieg
Hello
You know, you could link fx-parameters between parts in an assembly? Or you can create your include parts as derived part and derive the parameters you need. Both versions update parameter values automatically on change.
Or try this code.
Dim oAsmDoc As AssemblyDocument = ThisAssembly.Document
Dim oPartDoc As PartDocument
Dim oDoc As Document
Dim oPartCompDef As PartComponentDefinition
Dim oOcc As ComponentOccurrence
Dim oParam As UserParameter
For Each oDoc In oAsmDoc.AllReferencedDocuments
	If oDoc.DisplayName.StartsWith("Main") Then
		If oDoc.DocumentType = DocumentTypeEnum.kPartDocumentObject Then
			oPartDoc = TryCast(oDoc, PartDocument)
			If oPartDoc IsNot Nothing Then
				For Each oParam In oPartDoc.ComponentDefinition.Parameters.UserParameters
					If oParam.Name.StartsWith("x_") Then
						For Each oOcc In oAsmDoc.ComponentDefinition.Occurrences
							If oOcc.DefinitionDocumentType= DocumentTypeEnum.kPartDocumentObject  Then
								oPartCompdef = oOcc.Definition
								If oPartCompdef.Document.Displayname.StartsWith("Include") Then
									Try
										oPartCompdef.Parameters.UserParameters.Item(oParam.Name).Expression=oParam.Expression
									Catch
									End Try
								End If
							End If
						Next
					End If
				Next
			End If
		End If
	End If
Next
R. Krieg
RKW Solutions
www.rkw-solutions.com
Hi @Ralf_Krieg ,
I almost got it.
For now the code works only in one parameter,
Im not sure why.
[video]
Dim mParams As New ArrayList
Dim mParam As Parameter
Dim inPart As PartDocument
Dim inParts As New ArrayList
		oMain = occDoc
	Else If occDoc.DisplayName.Contains("Include") Then
		inPart = occDoc
		inParts.Add(inPart)
	End If
Next
For Each mParam In oMain.ComponentDefinition.Parameters
	If mParam.Name.Contains("x") Then
		mParams.Add(mParam)
	End If
Next
For Each inPart In inParts
	'This doesnt works.
	For Each inParam As Parameter In inPart.ComponentDefinition.Parameters
		If inParam.Name.Contains("x") AndAlso inParam.Name = mParam.Name Then
			inParam.Value = mParam.Value
		End If
	Next
Next
Ralf_Krieg
Hello
You need also to travers your collected mParams. Try
    For Each mParam As Parameter In mParams
		End If
    Next
Next
R. Krieg
RKW Solutions
Thank you @Ralf_Krieg .
		oMain = occDoc
		inPart = occDoc
		inParts.Add(inPart)
	End If
Next
		mParams.Add(mParam)
	End If
Next
			End If
		Next
	Next
Next
