API Inventor,
API Inventor,
API Inventor,
Here is a pretty  complicated task, would be really pleased for any help
Create a round table with manually changing diameter (scroll). The number of legs depends on diameter
need to:
crate a sketch and extrude details
release an assembly
create all constrains
create an interface for set parameters of details
rikard.nilsson
I think you go for iLogic.
I think it will be quite easy to create something that you describe with iLogic.
/Rikard
tolgay.hickiran
I'm with Rikard here.
If you are not on a mission to learn the API, you definetely go for ilogic because the case you are describing is actually a really easy one.
Some worthwhile ideas
Copy Design should rename ilogic Rules too!
Why Nastran In-CAD doesn't have an SDK?IMPLEMENTED!
Tolgay Hickiran
Founding Partner
SignatureSignature
website
emailskypelinkedinyoutubeemail
The problem is: I need to do this with API, this is work for University.
rikard.nilsson
It would be interesting to know why you need it to be API instead of using iLogic.
And one other thing.. I can't answer for everyone. But to get help it's better to ask specific questions of the problems that you have when you try to code.
If you haven't started yet I recommend to start reading the examples in the API help. There are a lot of examples that fits your question.
Regards
Rikard
Could you help me, please? Can't find syntaxis for creation a hole. Sorted out a face
 Dim RotationFaceOfAxis As Inventor.Face
        For Each RotationFaceOfAxis In oDocDef.Features.ExtrudeFeatures(1).Faces
            If RotationFaceOfAxis.SurfaceType = Inventor.SurfaceTypeEnum.kCylinderSurface Then Exit For
        Next
        If RotationFaceOfAxis.SurfaceType <> Inventor.SurfaceTypeEnum.kCylinderSurface Then Return
and don't know, what to do next
Hi! I made everything, just have a little problem: because my table is cylinder, there is an extra leg in center. Can I somehow avoid it?
 Dim oEdge As Inventor.Edge
        For Each oFace As Inventor.Face In oDetail.SurfaceBodies(1).Faces
            If oFace.SurfaceType = Inventor.SurfaceTypeEnum.kCylinderSurface Then
                For Each oEdge In oFace.Edges
                    If oEdge.GeometryType = Inventor.CurveTypeEnum.kCircleCurve Then
                        ''Другой компонент по новому вектору
                        Dim sFileName As String = "C:\Inventor\Nozhka.ipt"
                        Dim oCylinder1 As Inventor.ComponentOccurrence = oAssyDoc.ComponentDefinition.Occurrences.Add(sFileName, oPositionMatrix)
                        For Each oCylFace As Inventor.Face In oCylinder1.SurfaceBodies(1).Faces
                                Dim oConstr As Inventor.AssemblyConstraint = oAssyDoc.ComponentDefinition.Constraints.AddMateConstraint(oFace, oCylFace, 0, Inventor.InferredTypeEnum.kInferredLine, Inventor.InferredTypeEnum.kInferredLine)
                                Exit For
                        Next
                        Exit For
                Next
        Next
