API - get Parameter object from assembly constraint.
Jef_E
Jef_E
Hi there,
It's Answer Day, last time there was a seperate board for us to ask questions, now there isn't? So I suppose it's here we should ask the questions?
My question:
I’m looking for a way to get a parameters object from assembly constraints. I want to edit constraints via my addin, but can’t find the value for the constraint.
I have done this before with dimension constraints like this, but now I can’t find the solution for assembly constraints.
DimensionConstraint.Parameter() As Parameter
Please advise
Please kudo if this post was helpfull
Please accept as solution if your problem was solved
Inventor 2014 SP2
Something like MateConstraint.Offset, maybe?
The other AssemblyConstraints have similar properties: AngleConstraint.Angle, InsertConstraint.Distance, etc, that get you the Parameter you need to modify the constraint.
