API for the Format Text Box for adding parameter.
Mr_Justin_Hill
Mr_Justin_Hill
Is there a way to call the add parameter within the format text through API?
jjstr8
If you're asking if the API can click that button, the answer is no. You can use the API to add whatever object you're ultimately generating. See the link below for examples of adding drawing notes.
DrawingNotes Object
cidhelp
Hello @Mr_Justin_Hill,
you should look at the FormattedText of the Text-Object. FormattedText supports XML-Tags for Document Properties:
https://help.autodesk.com/view/INVNTOR/2025/ENU/?guid=GUID-915B75BA-4696-4fc7-A2C6-54B2BACDE7E1
