API - All Assembly Parts - Set End Of Part to Top Or Bottom
So, I have a snippet of code that I want to go through my assembly and roll the end of all parts up to expedite calculations. The issue is, it is grabbing the proxies instead of the actual components, so it throws an error.
Dim oDoc as Document
oDoc = ThisDoc.Document
Dim oOcc as ComponentOccurrence
Dim oAsmCompDef As AssemblyComponentDefinition
oAsmCompDef = oDoc.ComponentDefinition
For Each oOcc In oAsmCompDef.Occurrences.AllLeafOccurrences
    If oOcc.Definition.Type <> ObjectTypeEnum.kAssemblyComponentDefinitionObject Then
         oOcc.ComponentDefinition.SetEndOfPartToTopOrBottom(True)
    End If
Next
Vladimir.Ananyev
Here is the VBA sample that does this work:
Private Sub SetEOF()
    Dim oAssyDoc As AssemblyDocument
    Set oAssyDoc = ThisApplication.ActiveDocument
    Set oAsmCompDef = oAssyDoc.ComponentDefinition
    Dim oOcc As ComponentOccurrence
        If oOcc.Definition.Type = ObjectTypeEnum.kPartComponentDefinitionObject Then
            Dim oDef As PartComponentDefinition
            Set oDef = oOcc.Definition
            Call oDef.SetEndOfPartToTopOrBottom(True)
        End If
    Next
    oAssyDoc.Update
    Beep
End Sub
 Cheers,
Vladimir Ananyev
Developer Technical Services
Autodesk Developer Network
