- Mute
- Permalink
- Report
I'm making a little tool that will add some text on a drawing. Problem is, I want it to be attached to a view. So when I drag the view to a new location the text also moves. How can I achieve this?
I found this sample code in the programming help but it doesn't do the trick.
Public Sub SheetTextAdd() ' Set a reference to the drawing document. ' This assumes a drawing document is active. Dim oDrawDoc As DrawingDocument Set oDrawDoc = ThisApplication.ActiveDocument ' Set a reference to the active sheet. Dim oActiveSheet As Sheet Set oActiveSheet = oDrawDoc.ActiveSheet ' Set a reference to the GeneralNotes object Dim oGeneralNotes As GeneralNotes Set oGeneralNotes = oActiveSheet.DrawingNotes.GeneralNotes Dim oTG As TransientGeometry Set oTG = ThisApplication.TransientGeometry ' Create text with simple string as input. Since this doesn't use ' any text overrides, it will default to the active text style. Dim sText As String sText = "Drawing Notes" Dim oGeneralNote As GeneralNote Set oGeneralNote = oGeneralNotes.AddFitted(oTG.CreatePoint2d(3, 18), sText) ' Create text using various overrides. sText = "Notice: All holes larger than 0.500 n are to be lubricated." Set oGeneralNote = oGeneralNotes.AddFitted(oTG.CreatePoint2d(3, 16), sText) ' Create a set of notes that are numbered and aligned along the left. Dim dYCoord As Double dYCoord = 14 Dim dYOffset As Double Dim oStyle As TextStyle Set oStyle = oGeneralNotes.Item(1).TextStyle dYOffset = oStyle.FontSize * 1.5 ' Simple single line text. Set oGeneralNote = oGeneralNotes.AddFitted(oTG.CreatePoint2d(3, dYCoord), "1.") sText = "This is note 1." Set oGeneralNote = oGeneralNotes.AddFitted(oTG.CreatePoint2d(4, dYCoord), sText) ' Two line text. The two lines are defined using the tag within the text string. dYCoord = dYCoord - (oGeneralNote.FittedTextHeight + 0.5) Set oGeneralNote = oGeneralNotes.AddFitted(oTG.CreatePoint2d(3, dYCoord), "2.") sText = "This is note 2, which contains two lines." Set oGeneralNote = oGeneralNotes.AddFitted(oTG.CreatePoint2d(4, dYCoord), sText) ' Single line of text. dYCoord = dYCoord - (oGeneralNote.FittedTextHeight + 0.5) Set oGeneralNote = oGeneralNotes.AddFitted(oTG.CreatePoint2d(3, dYCoord), "3.") sText = "This is note 3." Set oGeneralNote = oGeneralNotes.AddFitted(oTG.CreatePoint2d(4, dYCoord), sText) ' Three lines of text. dYCoord = dYCoord - (oGeneralNote.FittedTextHeight + 0.5) Set oGeneralNote = oGeneralNotes.AddFitted(oTG.CreatePoint2d(3, dYCoord), "4.") sText = "This is note 4, which contains several lines." Set oGeneralNote = oGeneralNotes.AddFitted(oTG.CreatePoint2d(4, dYCoord), sText) dYCoord = dYCoord - (oGeneralNote.FittedTextHeight + 0.5) Set oGeneralNote = oGeneralNotes.AddFitted(oTG.CreatePoint2d(3, dYCoord), "5.") sText = "Here is the last and final line of text." Set oGeneralNote = oGeneralNotes.AddFitted(oTG.CreatePoint2d(4, dYCoord), sText) End Sub
Please kudo if this post was helpfull
Please accept as solution if your problem was solved
Inventor 2014 SP2
