Anyone work on Windows 7 with inventor 2010?
I play with my mac and bootcamp windows 7. I'm an beginner of Inventor 2010 API programming. Strange thing is I cannot find the SDK as the web suggests:
" If you’re using Windows XP this will typically be in:
C:\Program Files\Autodesk\Inventor 2010\SDK
If you’re using Windows Vista this will typically be in:
C:\Users\Public\Documents\Autodesk\Inventor 2010\SDK "
I searched my PC. There is just not SDK folder associated with inventor.
Then I tried to install the updated SDK. However, Usertools.msi fails no matter how i tried.
"Autodesk Inventor 2010 SDK Update (64 bit) (zip - 12796Kb)"
Anyone has similar exprience or any suggestion?
thx,
J
AlexFielder
I too struggled with this issue when attempting to install the SDK files on Windows 7 64-bit. Whenever I run the UserTools.msi file I get "There is a problem with this Windows Installer Package. A Program run as part of the setup did not finish as expected. Contact your support personnel or package vendor."
I still haven't gotten it to install.
Perhaps if enough of us complain they might fix it.
