Anybody get this to work at all
Hi i have tried to add a part to an active assmbly through VB in every way
possible but still cannot get it to work (Keep getting ActiveX cannot create
object errors) i have tried the help files but that is more based on macros.
Anybody willing to throw some code at me would be greatly appreciated.
Thanks Wayne
Wayne,
Try this:
Private Sub Command1_Click()
Dim oApp As Inventor.Application 'Get object
Dim strName As String 'string for file name
Set oApp = GetObject(, "Inventor.Application")
strName = "c:\temp\part1.ipt"
Call oApp.CommandManager.PostPrivateEvent(kFileNameEvent, strName)
Call oApp.CommandManager.StartCommand(kPlaceComponentCommand)
End Sub
See "Replace Component" for almost the same thing.
Wayne, you aren't from around Knoxville are you? Mike@RTSWright
Yehhaaaa this worked thank you very much. You cannot believe how long i have
tried to get this to work.
And to answer your question, no i am from South Africa->Durban.
Once again thank you.
"MDB" wrote in message
news:f098b8b.0@WebX.maYIadrTaRb...
Wayne,
Try this:
End Sub
Wayne,
Take a look at the AutoBolts sample that's delivered with Inventor. It does
this directly using the API, without executing the interactive command.
-Brian
"Wayne" wrote in message
news:A7CDEEC55D32B93CA37CBEBD1F16804B@in.WebX.maYIadrTaRb...
create
macros.
> Thanks Wayne
How come people are still using late bound objects?
Wayne,
Try this:
Dim oApp As
name
strName =
"c:\temp\part1.ipt"
Call
Call
End Sub
Wayne, you aren't
