Annotation
Annotation
Thetigerpirro
Message 1 of 18
Annotation
Thetigerpirro
Hi, I would like to add a code that automatically puts a Annotation in my model but i cant seem to find how.
What I'm doing is measuring the flat pattern and if it goes above my recommended size, i want it to show up as a annotation. Pop-ups wont work well and are way to intrusive for this. I also want the note to get deleted when it goes under my specified value.
All the measuring and stuff I can do myself but I dont know how to call the API to make/delete Annotations.
Accepted solutions (3)
Replies (17)
Message 2 of 18
WCrihfield
Under the PartComponentDefinition, you should find ModelAnnotations, then depending on what type of model annotation you want, you can either go the ModelDimensions, ModelGeneralNotes, or ModelLeaderNotes (or others), then you should find options for adding one.
Wesley Crihfield
(Not an Autodesk Employee)
Message 3 of 18
Thetigerpirro
Thanks. I have gotten a little bit further but I dont have a good grasp on how to work against API.
This is my code so far:
Dim partcompdef As PartComponentDefinition
partcompdef = ThisApplication.ActiveDocument.ComponentDefinition
partcompdef.ModelGeneralNoteDefinition.Add("kaka")
Any pointers?
Message 4 of 18
JhoelForshav
Hi @Thetigerpirro
This code will add the note:
Dim noteDef As ModelGeneralNoteDefinition = partcompdef.ModelAnnotations.ModelGeneralNotes.CreateDefinition("kaka", True)
Dim onote As ModelGeneralNote = partcompdef.ModelAnnotations.ModelGeneralNotes.Add(noteDef)
oNote.Name = "KAKA NOTE"
And this code will delete it:
On Error Resume Next
Dim oNote As ModelGeneralNote = partcompdef.ModelAnnotations.ModelGeneralNotes.Item("KAKA NOTE") 'Name of note
oNote.Delete
Hope it helps! 🙂
Message 5 of 18
Luisfmts
hi @JhoelForshav
First code, in an assembly environment,  for adding the General Note works fine. But the second one the method for deleting fails.
Do you know why? I also tried the Proxy but not sure if the implementation is similar.
Luís
Message 6 of 18
JhoelForshav
Hi @Luisfmts
I see that... I guess it's just a bug that you cannot delete ModelGeneralNotes in Assembly Environment.
Something like this as a workaround will have to do 🙂
Dim oAsm As AssemblyDocument = ThisDoc.Document
Dim odef As AssemblyComponentDefinition = oAsm.ComponentDefinition
Dim selSet As SelectSet = oAsm.SelectSet
selSet.Clear
selSet.Select(odef.ModelAnnotations.ModelGeneralNotes.Item("KAKA NOTE")) 'Name of note
ThisApplication.CommandManager.ControlDefinitions("AppDeleteCmd").Execute
Message 7 of 18
Luisfmts
Hi @JhoelForshav,
It worked perfectly. It is always nice to learn some new workarounds like this 😄
Thank you!
Message 8 of 18
ngdnam88
Hi @JhoelForshav
Can you share Code that delete all General Note in 3D Model?
Message 9 of 18
WCrihfield
Hi @ngdnam88.  Here is an iLogic rule you can try for deleting all ModelGeneralNote objects from a Part or Assembly document.  It can be used on either a Part or an Assembly, and can also be used as an external rule if needed.
Sub Main
	Dim oDoc As Document = ThisApplication.ActiveDocument
	Dim oMA As ModelAnnotations
	If oDoc.DocumentType = DocumentTypeEnum.kAssemblyDocumentObject Then
		Dim oADoc As AssemblyDocument = oDoc
		oMA = oADoc.ComponentDefinition.ModelAnnotations
	ElseIf oDoc.DocumentType = DocumentTypeEnum.kPartDocumentObject Then
		Dim oPDoc As PartDocument = oDoc
		oMA = oPDoc.ComponentDefinition.ModelAnnotations
	Else
		MsgBox("A Part or Assembly must be 'Active' for this rule to work.  Exiting.", vbExclamation, "iLogic")
		Exit Sub
	End If
	If oMA.ModelGeneralNotes.Count = 0 Then Exit Sub
	For Each oMGN As ModelGeneralNote In oMA.ModelGeneralNotes
		oMGN.Delete
	Next
End Sub
If this solved your problem, or answered your question, please click ACCEPT SOLUTION.
Or, if this helped you, please click (LIKE or KUDOS) 👍.
If you want and have time, I would appreciate your Vote(s) for My IDEAS 💡 or you can Explore My CONTRIBUTIONS
Wesley Crihfield
Message 10 of 18
ngdnam88
Thanks @WCrihfield
It's working perfectly!
Message 11 of 18
ngdnam88
Hi @WCrihfield
I just tested one more times and got a problem with assembly. Please help me. Thanks,
Message 12 of 18
ngdnam88
Hi @WCrihfield
Message 13 of 18
JhoelForshav
Hi @ngdnam88
The code @WCrihfield posted works for inventor 2022. For older versions though (don't know about 2021, but at least 2020 and earlier), there's a bug when it comes to deleting annotations in assemblies. That's why I wrote a workaround for that earlier in this thread. I have modified @WCrihfield's code to use this workaround for assemblies. Hope it helps!
Sub Main
	Else
		Exit Sub
	End If
		Dim oSelSet As SelectSet = oDoc.SelectSet
		Dim oCol As ObjectCollection = ThisApplication.TransientObjects.CreateObjectCollection
			oCol.Add(oMGN)
		Next
		oSelSet.SelectMultiple(oCol)
	Else
			oMGN.Delete
		Next
	End If
End Sub
Message 14 of 18
ngdnam88
I'm using Inventor 2018.3. Your code is working perfectly!
Thanks you very much!
Message 15 of 18
ngdnam88
Dears @JhoelForshav @WCrihfield
Is possible rename it to new name?
Message 16 of 18
WCrihfield
Hi @ngdnam88.  Yes.  Much like before, you just have to dig down to that ModelGeneralNote object, then change the value of its Name property to something else.  The following code is just a very basic example for doing that in an assembly, which has just one ModelGeneralNote.  It just had its default name before running the code, then when I ran this code, it change its name to "INFO", just like in your image.
Dim oADoc As AssemblyDocument = ThisDoc.Document
Dim oMAs As ModelAnnotations = oADoc.ComponentDefinition.ModelAnnotations
Dim oMGN As ModelGeneralNote = oMAs.ModelGeneralNotes.Item(1)
oMGN.Name = "INFO"
If this solved your problem, or answered your question, please click ACCEPT SOLUTION .
Wesley Crihfield
Message 17 of 18
DeckTechnick
Message 18 of 18
DeckTechnick
I have a similar problem:
I tried to put a note baseded  in user parameter (kind "int_ref=1.234") into a model general note (into kUpperLeftQuadrant), and when i use
"<Parameter Resolved='True' ComponentIdentifier='" & oDoc.FullDocumentName & "' Name='int_ref' Precision='2'>" & Parameter("int_ref") & "</Parameter>"
 it keep me sending the same error:
"The parameter is incorrect. (Exception from HRESULT: 0x80070057 (E_INVALIDARG))"
The error persist in assamblies and parts documents.
Can u tell what is wrong ?
