Alpha Sort Component: natural sorting order
progettazionesviluppo
I would appreciate if someone already had made the code that would sort the occurences within the browser in natural order (as on the immage bellow).
Thanks!
Andrii_Humeniuk
Hi @progettazionesviluppo .
Inventor has a built-in Alpha Sort Components function, but I personally don't know of a separate method for this function in the API. Therefore, I recommend you to use the following iLogic rule on this topic:
Public Class ThisRule
    Sub Main()
        Dim doc As AssemblyDocument = ThisDoc.Document
        Dim topNode As BrowserNode = doc.BrowserPanes.Item("Model").TopNode
        Dim nodesList As List(Of BrowserNode) = New List(Of BrowserNode)()
        Dim orginNode As BrowserNode = Nothing
        For Each node As BrowserNode In topNode.BrowserNodes
            If (node.BrowserNodeDefinition.Label.Equals("Origin")) Then
                orginNode = node
            End If
            If (node.NativeObject IsNot Nothing) Then
                If (node.NativeObject.Type = ObjectTypeEnum.kComponentOccurrenceObject) Then
                    nodesList.Add(node)
                End If
            End If
        Next
        Dim nodeArray() = nodesList.ToArray()
        Array.Sort(nodeArray, New AlphanumReverseComparator())
        Dim transAction As Transaction = ThisApplication.TransactionManager.StartTransaction(ThisDoc.Document, "Alphanum sort")
        For Each node As BrowserNode In nodeArray
            doc.BrowserPanes.Item("Model").Reorder(orginNode, False, node)
        Next
        transAction.End()
    End Sub
End Class
Public Class AlphanumReverseComparator
    Implements IComparer
    ' Taken from:
    ' https://www.dotnetperls.com/alphanumeric-sorting-vbnet
    Public Function Compare(ByVal x As Object,
                            ByVal y As Object) As Integer Implements IComparer.Compare
        ' [1] Validate the arguments.
        Dim s1 As String = y.BrowserNodeDefinition.Label
        If s1 = Nothing Then
            Return 0
        End If
        Dim s2 As String = x.BrowserNodeDefinition.Label
        If s2 = Nothing Then
            Return 0
        End If
        Dim len1 As Integer = s1.Length
        Dim len2 As Integer = s2.Length
        Dim marker1 As Integer = 0
        Dim marker2 As Integer = 0
        ' [2] Loop over both Strings.
        While marker1 < len1 And marker2 < len2
            ' [3] Get Chars.
            Dim ch1 As Char = s1(marker1)
            Dim ch2 As Char = s2(marker2)
            Dim space1(len1) As Char
            Dim loc1 As Integer = 0
            Dim space2(len2) As Char
            Dim loc2 As Integer = 0
            ' [4] Collect digits for String one.
            Do
                space1(loc1) = ch1
                loc1 += 1
                marker1 += 1
                If marker1 < len1 Then
                    ch1 = s1(marker1)
                Else
                    Exit Do
                End If
            Loop While Char.IsDigit(ch1) = Char.IsDigit(space1(0))
            ' [5] Collect digits for String two.
            Do
                space2(loc2) = ch2
                loc2 += 1
                marker2 += 1
                If marker2 < len2 Then
                    ch2 = s2(marker2)
                Else
                    Exit Do
                End If
            Loop While Char.IsDigit(ch2) = Char.IsDigit(space2(0))
            ' [6] Convert to Strings.
            Dim str1 = New String(space1)
            Dim str2 = New String(space2)
            ' [7] Parse Strings into Integers.
            Dim result As Integer
            If Char.IsDigit(space1(0)) And Char.IsDigit(space2(0)) Then
                Dim thisNumericChunk = Integer.Parse(str1)
                Dim thatNumericChunk = Integer.Parse(str2)
                result = thisNumericChunk.CompareTo(thatNumericChunk)
            Else
                result = str1.CompareTo(str2)
            End If
            ' [8] Return result if not equal.
            If Not result = 0 Then
                Return result
            End If
        End While
        ' [9] Compare lengths.
        Return len1 - len2
    End Function
End Class
Andrii Humeniuk - CAD Coordinator, Autodesk Certified Instructor
LinkedIn | My free Inventor Addin | My Repositories
Did you find this reply helpful ? If so please use the Accept as Solution/Like.
Slow, but worsk very well.
Thanks!
fredform
I found that the productivity tools can be triggered thru their internal command ID like this:
Try
    Dim cmd As ControlDefinition
    cmd = ThisApplication.CommandManager.ControlDefinitions.Item("AssemblyBonusTools_AlphaSortComponentsCmd")
    cmd.Execute()
Catch ex As Exception
    MsgBox("Could not execute Alpha Sort Components command." & vbCrLf & ex.Message)
End Try
This is the equivalent of clicking the button in the UI.
For reference, I used this code to output all the command IDs:
Dim cm As CommandManager = ThisApplication.CommandManager
Dim filePath As String = "C:\Temp\Inventor_CommandIDs.txt"
Dim sw As New System.IO.StreamWriter(filePath, False)
For Each cd As ControlDefinition In cm.ControlDefinitions
    sw.WriteLine(cd.InternalName & "  |  " & cd.DisplayName)
Next
sw.Close()
MsgBox("Done! File written to: " & filePath)
Best,
Fredrik
g.georgiades
I recommend using defer updates while reordering - it speeds it up quite a bit
ThisApplication.AssemblyOptions.DeferUpdate = True
