AddUsingiMates Crashes the Inventor
Mehmet_Fatih_Turker
Message 1 of 1
Mehmet_Fatih_Turker
Hi all,
I have a crash at the line of;
Dim LiftingSheetCompOcc As Inventor.ComponentOccurrence = AG_CW_BOB_MONcompdef.Occurrences.AddUsingiMates(liftingSheetPath, True)
I already filled crash report with ID number of 805948009
Simply I want to bring specific part to assembly by using its iMate feature. I guess my problem is with AddUsingiMates method because I've added 10 to 12 parts into assy and constrained them before the line that I mentioned above. as an example how Im adding parts into assembly  ;
                If isZ Or isL Then
                    For i As Integer = 1 To 2
#Region "Adding and Constraining ... Here"
                        Dim topandBottomIsoCompOcc As Inventor.ComponentOccurrence = docN_B_McompDef.Occurrences.Add(isoTopBottomPath, defaultMatrix)
                        Dim topandBottomIsoDoc As Inventor.AssemblyDocument = topandBottomIsoCompOcc.Definition.Document
                        topandBottomIsoCompOcc.Grounded = False
#Region "Plane and Plane Proxies"
                        Dim t_b_isoYZPlane As WorkPlane = topandBottomIsoDoc.ComponentDefinition.WorkPlanes.Item("YZ Plane")
                        Dim t_b_isoYZPlaneProxy As WorkPlaneProxy
                        topandBottomIsoCompOcc.CreateGeometryProxy(t_b_isoYZPlane, t_b_isoYZPlaneProxy)
                        Dim t_b_isoXYPlane As WorkPlane = topandBottomIsoDoc.ComponentDefinition.WorkPlanes.Item("XY Plane")
                        Dim t_b_isoXYPlaneProxy As WorkPlaneProxy
                        topandBottomIsoCompOcc.CreateGeometryProxy(t_b_isoXYPlane, t_b_isoXYPlaneProxy)
                        Dim t_b_isoXZPlane As WorkPlane = topandBottomIsoDoc.ComponentDefinition.WorkPlanes.Item("XZ Plane")
                        Dim t_b_isoXZPlaneProxy As WorkPlaneProxy
                        topandBottomIsoCompOcc.CreateGeometryProxy(t_b_isoXZPlane, t_b_isoXZPlaneProxy)
#End Region
#Region "Constraints"
                        If i = 1 Then
                            Dim t_b_iso1 As MateConstraint = docN_B_McompDef.Constraints.AddMateConstraint(oN_B_MUserPlane11, t_b_isoXYPlaneProxy, 0)
                            Dim t_b_iso2 As FlushConstraint = docN_B_McompDef.Constraints.AddFlushConstraint(t_b_isoYZPlaneProxy, oN_B_MYZPlane, "Kademe_Kaydirma_Toplam_Kalinligi / 2 ul")
                            Dim t_b_iso3 As MateConstraint = docN_B_McompDef.Constraints.AddMateConstraint(oN_B_MXZPlane, t_b_isoXZPlaneProxy, 0)
                        Else
                            Dim t_b_iso4 As FlushConstraint = docN_B_McompDef.Constraints.AddFlushConstraint(t_b_isoYZPlaneProxy, oN_B_MYZPlane, "Kademe_Kaydirma_Toplam_Kalinligi / 2 ul")
                            Dim t_b_iso5 As FlushConstraint = docN_B_McompDef.Constraints.AddFlushConstraint(oN_B_MUserPlane4, t_b_isoXYPlaneProxy, 0)
                            Dim t_b_iso6 As FlushConstraint = docN_B_McompDef.Constraints.AddFlushConstraint(oN_B_MXZPlane, t_b_isoXZPlaneProxy, 0)
#End Region
#End Region
                    Next
This works so far so good but Crashes at at the AddUsingiMates method. Is there anyone experienced such problem?
Please dont ask me for whole code because it reached to almost 15k line here. I could have shared as zip but company doesnt  allow me to.
Replies (0)
