Address fist level children only
c.bloedorn
c.bloedorn
Hi I found this code which does almost exactly what I would like it to do. The only change I need, is for it to not use AllReferencedDocuments and instead only change the iproperty of the immediate children only. Is this possible to do?
Thanks in advance for any help!
I copied this code from @A.Acheson so credit goes to him!
Dim oAssyDoc As AssemblyDocument
 oAssyDoc = ThisApplication.ActiveDocument
 ' Get the Design Tracking property set.
Dim AssyDesignPropSet As PropertySet
AssyDesignPropSet = oAssyDoc.PropertySets.Item("Design Tracking Properties")
' Get the Description property.
Dim AssyProj As Inventor.Property
AssyProj = AssyDesignPropSet.Item("Part Number")
'Get all of the referenced documents.
Dim oRefDocs As DocumentsEnumerator
oRefDocs = oAssyDoc.AllReferencedDocuments
'Iterate through the list of documents.
Dim oRefDoc As Document
For Each oRefDoc In oRefDocs
	' If oRefDoc.DocumentType = DocumentTypeEnum.kPartDocumentObject Then
'		Logger.Info("DisplayName: "& oRefDoc.DisplayName)'FileName
'		Logger.Info("FullFileName: "& oRefDoc.FullFileName)'FilePath
         Dim DesignTrackPropSet As PropertySet
         DesignTrackPropSet = oRefDoc.PropertySets.Item("Design Tracking Properties")
                Dim RefProj As Inventor.Property
         RefProj = DesignTrackPropSet.Item("Project")
   		Try
			RefProj.Value = AssyProj.Value
		Catch
			Logger.Info("Read Only - "& oRefDoc.DisplayName )
		End Try
    'End If
Next
WCrihfield
Hi @c.bloedorn.  Have you tried simply changing this line:
...to this:
oRefDocs = oAssyDoc.ReferencedDocuments
I'm thinking that may do what you want.  If not, then we may switch from iterating through referenced documents to iterating through components.
Wesley Crihfield
(Not an Autodesk Employee)
