- Mute
- Permalink
- Report
A while ago i struggled with the below code and with your help i've worked with it pleasently. Now the question is to add the revision number of the exported document to the filename (if there is a revision number).
This code is used to export current or all open drawings to PDF and/or DWG. This saves a lot of time to export 50+ drawings of a project.
When i edit the code i'm coming to 2 outcome's:
1. it is looking at the revision number of the shown model and not the drawings revision number.
2. it is only looking at the current open drawing's revision number and adding it to all filenames.
Now i can update the revision numbers to the models by hand, but that's not ideal.
Sub Main() oInvApp = ThisApplication Dim myDate As String = Now().ToString("dd-MM-yyyy") myDate = myDate.Replace(":","") ' & " - " & TypeString userChoice = InputRadioBox("Defined the scope", "This Document", "All Open Documents", True, Title := "Defined the scope") UserSelectedActionList = New String(){"DWG & PDF", "PDF Only", "DWG Only"} UserSelectedAction = InputListBox("What action must be performed with selected views?", _ UserSelectedActionList, UserSelectedActionList(0), Title := "Action to Perform", ListName := "Options") Select UserSelectedAction Case "DWG & PDF": UserSelectedAction = 3 Case "PDF Only": UserSelectedAction = 1 Case "DWG Only": UserSelectedAction = 2 End Select If userChoice Then Call MakePDFFromDoc(oInvApp.ActiveDocument, myDate, UserSelectedAction) Else For Each oDoc In oInvApp.Documents If oDoc.DocumentType <> kDrawingDocumentObject Then Continue For Try If Len(oDoc.File.FullFileName) > 0 Then Call MakePDFFromDoc(oDoc, myDate, UserSelectedAction) End If Catch End Try Next End If End Sub Dim oInvApp As Inventor.Application Sub MakePDFFromDoc(ByRef oDocument As Document, DateString As String, UserSelectedAction As Integer) 'oPath = oDocument.Path 'oFileName = oDocument.FileName(False) 'without extension 'oDocument = ThisApplication.ActiveDocument Dim sDescript As String = oDocument.PropertySets("Design Tracking Properties")("Description").Value oPDFAddIn = oInvApp.ApplicationAddIns.ItemById("{0AC6FD96-2F4D-42CE-8BE0-8AEA580399E4}") oContext = oInvApp.TransientObjects.CreateTranslationContext oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism oOptions = oInvApp.TransientObjects.CreateNameValueMap oDataMedium = oInvApp.TransientObjects.CreateDataMedium oFullFileName = oDocument.File.FullFileName oPath = Left(oFullFileName, InStrRev(oFullFileName, "\")-1) oFileName = Right(oFullFileName, Len(oFullFileName)-InStrRev(oFullFileName, "\")) ' oFilePart = Left(oFileName, InStrRev(oFileName, ".") - 1) oFilePart = Left(oFileName, InStrRev(oFileName, ".") - 1) & " " & sDescript 'oRevNum = oDocument.iProperties.Value("Project", "Revision Number") 'oDocument = ThisApplication.ActiveDocument 'If oPDFAddIn.HasSaveCopyAsOptions(oDataMedium, oContext, oOptions) Then oOptions.Value("All_Color_AS_Black") = 0 oOptions.Value("Remove_Line_Weights") = 1 oOptions.Value("Vector_Resolution") = 400 oOptions.Value("Sheet_Range") = Inventor.PrintRangeEnum.kPrintAllSheets 'oOptions.Value("Custom_Begin_Sheet") = 2 'oOptions.Value("Custom_End_Sheet") = 4 ' End If 'get PDF target folder path 'oFolder = Left(oPath, InStrRev(oPath, "\")) & "PDF" oFolder = oPath & "\Export DWG & PDF (" & DateString & ")" oDirectoryName = System.IO.Path.GetDirectoryName(oFullFileName) 'Check for the PDF folder and create it if it does not exist If Not System.IO.Directory.Exists(oFolder) Then System.IO.Directory.CreateDirectory(oFolder) End If 'Set the PDF target file name oDataMedium.FileName = oFolder & "\" & oFilePart & ".pdf" 'Publish document If (UserSelectedAction = 1) Or (UserSelectedAction = 3) Then oPDFAddIn.SaveCopyAs(oDocument, oContext, oOptions, oDataMedium)'For PDF's End If If (UserSelectedAction = 2) Or (UserSelectedAction = 3) Then oDocument.SaveAs(oFolder & "\" & oFilePart & ".dwg", True) 'For DWG's End If 'oDocument.SaveAs(oFolder & "\" & ThisDoc.ChangeExtension(".DWG"), True) 'For DWG's '------end of iLogic------- End Sub
