Adding more holes as face length increases / remove holes as length of face decreases.
talha_ozdemir
Message 1 of 8
talha_ozdemir
Hello there. I wonder if I can add a rule in iLogic where it will add automatic holes per given length, also same way where it will remove. For example I have a profıle which is 2 meters and it has 6 holes there. I want it to add 3 more holes when I increase the lenght of profile 1 more meter.
Replies (7)
Message 2 of 8
basautomationservices
Hi there,
This is possible. Do you have an example part perhaps?
Maybe this could just be solved with a pattern and the pattern count that depends on the length?
Contact me for custom app development [email protected]. Follow below links to view my Inventor appstore apps.
Free apps: Smart Leader | Part Visibility Utility | Mate Origins
Paid apps: Frame Stiffener Tool | Constrain Plane Toggle | Property Editor Pro
Message 3 of 8
talha_ozdemir
Here is the example as ipt. I am not sure how to solve with pattern count honestly.
Message 4 of 8
I think this is solved best using a pattern because the holes have equal spacing.
You can do this by creating a unitless parameter called count, and a distance parameter called spacing. Set the amount of holes to count, count being round(length / spacing).
If you require a minimum start/end offset, calculate the effective length (-2*offset), and use that before dividing by spacing. You can also use a fitted pattern to specifiy the total distance and the amount of holes instead of the spacing
Message 5 of 8
petr.meduna
Hi, yes you can. You can use simple iLogic rule for counting holes or you can write an equation directly in the textbox of pattern window. I attached your file below for demo.
Message 6 of 8
talha_ozdemir
Hey,
Thank you very much I opened it and it worked. Also understood how it works. Much appreciated.
Message 7 of 8
yan.gauthier
This sort of feature is best done with pattern and parameter equation.
this example fixes the center-center distance. You could change it to fix the quantity or the side distance
Message 8 of 8
talha_ozdemir
Wow. It looks a bit complicated but I will give it a try, thanks !
