Wonderful, thanks Bob. I'll have a look and let you know how it goes.
Sean Dotson, PE
www.sdotson.com
Autodesk Inventor Certified Expert
Sidel, Engineering & Manufacturing Manager
"Bob S." wrote in message
news:41c19432$1_1@newsprd01...
> Sean,
> These are just kind of rough snippets from my own addin which should point
you in the
> proper direction for adding to the Tools menu. Everything I have posted
here is in my
> ApplicationAddInServer_Activate sub. As you may notice, there are actually
7 seperate
> Tools menus. This code actually creates a submenu under the Tools menu
(with only 1 entry)
> but you should be able to deduce how to do just a single menu item too, I
would think.
> Bob S.
> in ApplicationAddInServer_Activate :
> Set moShadyBobUtilBar2 =
oApp.CommandManager.ControlDefinitions.AddButtonDefinition _
> ("Settings", "SC_BobUtilsettings", kQueryOnlyCmdType, _
> "{}", _
> "Display settings for Shady Bob's Inventor Utilities", "Settings",
_
> oIcon4, oIcon4)
> ' Find the command bar of the "Tools" pop-up menu.
> Dim oUIManager As UserInterfaceManager
> Set oUIManager = oApp.UserInterfaceManager
> ' Create a command bar of a pop-up type for a flyout.
> Dim oFlyOutCmdBar As CommandBar
> Set oFlyOutCmdBar = oUIManager.CommandBars.Add("Bob's Utilities", _
> "FlyoutCmdBar", kPopUpCommandBar, "")
> ' Add 1 button to the fly-out command bar.
> Call oFlyOutCmdBar.Controls.AddButton(moShadyBobUtilBar2)
> Dim oMenuPopupCmdBar As CommandBar
> Set oMenuPopupCmdBar = oUIManager.CommandBars.Item("AppToolsMenu")
> ' Add the fly-out to the menu pop-up.
> Call oMenuPopupCmdBar.Controls.AddPopup(oFlyOutCmdBar)
oUIManager.CommandBars.Item("AssemblyToolsMenu")
oUIManager.CommandBars.Item("DrawingMangerToolsMenu")
oUIManager.CommandBars.Item("NotebookToolsMenu")
oUIManager.CommandBars.Item("PartFeatureToolsMenu")
> Set oMenuPopupCmdBar = oUIManager.CommandBars.Item("PartToolsMenu")
oUIManager.CommandBars.Item("PresentationToolsMenu")
> "Sean Dotson" wrote in message
news:41c18af4_3@newsprd01...
> > While this will work I do believe this is the old method. It works in
R9
> > but will not be supported so may break in future versions. If I'm wrong
> > please let me know.
> > Sean Dotson, PE
> > www.sdotson.com
> > "Mika Aaltonen" wrote in message
> > news:41c186a0_3@newsprd01...
> >> This code works in IV8 and IV9 addin..Add this code to a class module.
I
> >> hope this helps.
> >> Option Explicit
> >> 'Form should be loaded in modality mode.
> >> Public Enum frmModality
> >> frmModal = vbModal
> >> frmModeless = vbModeless
> >> End Enum
> >> 'Implements for ApplicationAddInServer
> >> Implements ApplicationAddInServer
> >> 'Public AddInSite As ApplicationAddInSite
> >> 'Public InventorApp As InventorFramework.Application
> >> Public InventorApp As Inventor.Application
> >> 'Define command.
> >> Private Command1 As Command
> >> Public Sub ApplicationAddInServer_Activate(ByVal AddInSiteObject As
> >> Inventor.ApplicationAddInSite, ByVal FirstTime As Boolean)
> >> 'Inside Activate
> >> 'Save the Add-In site object in a global variable.
> >> Set AddInSite = AddInSiteObject
> >> 'Save the Invertor Application object.
> >> Set InventorApp = AddInSite.Application
> >> 'Create the first command.
> >> Set Command1 = AddInSite.CreateCommand("Property Management", 1,
True)
> >> 'Set command to enabled to use command properties.
> >> Command1.Enabled = True
> >> Set AddInSite = Nothing
> >> Set InventorApp = Nothing
> >> Set Command1 = Nothing
> >> End Sub
> >> 'These subs must be here even there is not any code otherwise compiler
> >> deletes these subs and
> >> 'program dosn't work.
> >> 'Public Property Get ApplicationAddInServer_Automation() As
> >> Inventor.AddInAutomation
> >> Public Property Get ApplicationAddInServer_Automation() As Object
> >> 'Inside Automation
> >> End Property
> >> Public Sub ApplicationAddInServer_Deactivate()
> >> 'Inside Deactivate
> >> End Sub
> >> Public Sub ApplicationAddInServer_ExecuteCommand(ByVal CommandID As
Long)
> >> 'If program is executed by clicking it from Tools bar then we will call
> > it's
> >> form.
> >> Select Case CommandID
> >> Case 1
> >> Call ShowPropertiesForm
> >> End Select
> >> End Sub
> >> Public Sub ShowForm(Optional Modality As _
> >> frmModality = frmModal)
> >> 'Call frm Form as Modality mode.
> >> frm.Show Modality
> >> End Sub
> >> Public Sub ShowPropertiesForm(Optional Modality As _
> >> 'Call frmProperties form as Modality mode.
> >> frmProperties.Show Modality
> >> End Sub
> >> Public Sub ShowDrawingSettingsForm(Optional Modality As frmModality =
> >> frmModal)
> >> frmDrawingSettings.Show Modality
> >> End Sub
