Adding i-Part to an assembly using components.addIPart resulting in an error
athirumalareddy
athirumalareddy
Hi, I am trying to add a component into an assembly using i-logic  "Components.AddiPart" function.
Select Case Diameter
        Case 3
              BearingArm = "310D603105"
        Case 5
              BearingArm = "310D029032"
        Case 7
              BearingArm = "310D613163"
End Select
MessageBox.Show(BearingArm , "Bearing Arm")
Dim oPath As String = "C:\_VaultWorkspace\Designs\3D models\BEARING ARM\"
Dim BA1 = Components.AddiPart(BearingArm, oPath & BearingArm & ".ipt", BearingArm)
Here is the i-part table..
Does the Member name needs to be always an integer type?
I think that FindRow means, you need to insert number of row in ipart table (I know that function description is missleading)
So please change:
into:
Dim BA1 = Components.AddiPart(BearingArm, oPath & BearingArm & ".ipt", 1)
That should work, bu I don't know if that is enough fo you.
