Adding file to a browser folder
MattH_Work
MattH_Work
I'm using the following sample code to add files to a browser folder
Public Sub AddOccurrencesToFolder()
    Dim oDoc As AssemblyDocument     Set oDoc = ThisApplication.ActiveDocument
    Dim oDef As AssemblyComponentDefinition     Set oDef = oDoc.ComponentDefinition
    Dim oPane As BrowserPane     Set oPane = oDoc.BrowserPanes.ActivePane
    Dim oOccurrenceNodes As ObjectCollection     Set oOccurrenceNodes = ThisApplication.TransientObjects.CreateObjectCollection
    Dim oOcc As ComponentOccurrence     For Each oOcc In oDef.Occurrences
        Dim oNode As BrowserNode         Set oNode = oPane.GetBrowserNodeFromObject(oOcc)
        oOccurrenceNodes.Add oNode     Next
    Dim oFolder As BrowserFolder     Set oFolder = oPane.AddBrowserFolder("My Occurrence Folder", oOccurrenceNodes)
End Sub
How do I get the files added to an existing " My Occurrence Folder" rather than creating a new one. Every time I run the code a new folder is created, it does not use the exisitng one
cheers
Matt
MattH
Product Design Collection 2026
Vault Pro 2026
philippe.leefsma
Hi Matt,
How about using "BrowserFolder.Add" Method.
You should be able to retrieve an existing BrowserFolder by parsing the browser nodes and use "BrowserNode.BrowserFolders" property to acess it.
Please refer to the Help Files for more details about those APIs.
Philippe Leefsma
Developer Technical Services
Autodesk Developer Network
Hi Philippe,
Can you please post an example iLogic code using the "BrowserFolder.Add" method? I am using iLogic to place components then move then to a folder, and I can't figure out how to add component occurrences to a specific folder.
Paul
Jef_E
I know this is an old topic, but I was searching for this solution and it was lacking the requested sample.
Here is the sample that works for me. I hope someone else can also benefit from this "late" response.
' get the model browser pane
oPane = oAssemblyDoc.BrowserPanes.Item("Model")
' Create a Browser node object from an existing object
oNode = oPane.GetBrowserNodeFromObject(oOccurrence)
' Add the node to the extra folder
oPane.TopNode.BrowserFolders.Item("Extra").Add(oNode)
Please kudo if this post was helpfull
Please accept as solution if your problem was solved
Inventor 2014 SP2
