Adding Custom Iproperty with formula
J.VandeMerckt
J.VandeMerckt
Hi everyone
I want to add a Custom Iproperty looking like this
Right now I'm using this code but it just adds the Iproperty and uses the current appearance.
iProperties.Value("Custom", "Color")=iProperties.PartColor
 The value should change when the color changes.
Therefore the value should be =<Appearance>
I can't figure out how I can add this value using Ilogic.
Can anyone help me update the code?
Can't find it on trusty google.
Thanks in advance!
BR
WCrihfield
Hi @J.VandeMerckt.  Try this:
iProperties.Value("Custom", "Color") = "=<Appearance>"
It just so happens that there is a standard iProperty already named "Appearance" near the end of the third PropertySet, which makes this work, because otherwise you would have to have a custom iProperty named Appearance, then have a way to keep its value up to date every time the appearance changed.  And there is no event in the Event Triggers dialog for only changing the appearance of a part, but there is one for changing its material.
If this solved your problem, or answered your question, please click ACCEPT SOLUTION .
Or, if this helped you, please click (LIKE or KUDOS) 👍.
Wesley Crihfield
(Not an Autodesk Employee)
WCrihfield
Below are two different ways to access the standard iProperty, so that you do not even need to create the custom one.
Dim sAppearance1 As String = iProperties.Value("Project", "Appearance")
Logger.Info("Appearance 1 = " & sAppearance1)
Dim sAppearance2 As String = ThisDoc.Document.PropertySets.Item(3).Item("Appearance").Value
Logger.Info("Appearance 2 = " & sAppearance2)
When I ran that rule on my part, the results in my iLogic Log window were as follows (which was correct, and stayed up to date):
INFO| 3: >>---------------------------
INFO|Appearance 1 = Dark Gray
INFO|Appearance 2 = Dark Gray
Wesley Crihfield
J.VandeMerckt
Hi Thank you for your response.
Good to know but I still need to know how to add a custom iProperties with a formula as value.
The system I'm using is now programmed to search for the custom iProperties and not the imbedded Inventor properties.
Br
J.VandeMerckt
On a second look.
It seems that the people who setup this "system" have cleaned up their code.
Now it looks for the imbedded appearance Property instead of a custom one.
So no problem anymore.
Tnx for the help either way.
