Adding contraints with VBA
I have an assembly that contains multiple parts. I have been successful at adding parts with VBA code, but want to place constraints (mate and flush) on the parts I add. I created work planes specifically for this task in each of the parts I want to constrain. If I mate Work PlaneX in Part1 to Work PlaneZ in Part2, I will have exactly what I'm looking for. Below is the VBA code I have been using to try this. The code references specific Part Documents and Work Planes. These are working properly (referencing the correct parts and documents). The constraint call is the only thing not working. Am I on the right track?
TIA,
Chris Gitzlaff
Code:
Dim oAsmCompDef As AssemblyComponentDefinition
Set oAsmCompDef = ThisApplication.ActiveDocument.ComponentDefinition
Dim oPt1CompDef As PartComponentDefinition
Dim oPt2CompDef As PartComponentDefinition
Dim oMate As MateConstraint
Dim oWPlane1 As WorkPlane
Dim oWPlane2 As WorkPlane
Set oPt1CompDef = ThisApplication.Documents.Item(3).ComponentDefinition
Set oWPlane1 = oPt1CompDef.WorkPlanes.Item(9)
Set oPt2CompDef = ThisApplication.Documents.Item(6).ComponentDefinition
Set oWPlane2 = oPt2CompDef.WorkPlanes.Item(4)
Set oMate = oAsmCompDef.Constraints.AddMateConstraint(oWPlane1, oWPlane2, 0, kInferredLine, kInferredLine)
Chris,
The last two arguments need to be
face="Times New Roman" size=3>kNoInference in this case since you are
constraining planes. kInferredLine is valid only for cylindrical & conical
surfaces. Please see the help file for valid combinations.
Sanjay-
Inventor API
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
I
right track?
TIA,
Chris Gitzlaff
Code:
Set
Dim oPt2CompDef As
Thanks for the response, but it wasn't the solution. I had tried the kNoInference options before (all combinations, really). I have a feeling that I'm going about this the wrong way. What I would really like to see is an example where two parts (any parts) are placed in a model, then constrained using VBA. I suspect my problem is that I'm referencing parts, not occurrences, but I'm not sure.
Thanks for your help,
Chris G.
I figured it out 🙂 I had placed a chunk of code into a temporary module a few days ago, but hadn't looked at it. It was the solution! I think it may have come straight out of the help files - it has excellent comments. The problem - I was referencing the parts, not the occurrences.
Anyway, here is the code:
' Get references to the two occurrences to constrain.
' This arbitrarily gets the first and second occurrence.
Dim oOcc1 As ComponentOccurrence
Set oOcc1 = oAsmCompDef.Occurrences.Item(1)
Dim oOcc2 As ComponentOccurrence
Set oOcc2 = oAsmCompDef.Occurrences.Item(2)
' Get the XY plane from each occurrence. This goes to the
' component definition of the part to get this information.
' This is the same as accessing the part document directly.
' The work plane obtained is in the context of the part,
' not the assembly.
Dim oPartPlane1 As WorkPlane
Set oPartPlane1 = oOcc1.Definition.WorkPlanes.Item(3)
Dim oPartPlane2 As WorkPlane
Set oPartPlane2 = oOcc2.Definition.WorkPlanes.Item(3)
' Because we need the work plane in the context of the assembly
' we need to create proxies for the work planes. The proxies
' represent the work planes in the context of the assembly.
Dim oAsmPlane1 As WorkPlaneProxy
Call oOcc1.CreateGeometryProxy(oPartPlane1, oAsmPlane1)
Dim oAsmPlane2 As WorkPlaneProxy
Call oOcc2.CreateGeometryProxy(oPartPlane2, oAsmPlane2)
' Create the constraint using the work plane proxies.
Call oAsmCompDef.Constraints.AddMateConstraint(oAsmPlane1, oAsmPlane2, 0)
Chris Gitzlaff
