Adding buttons to the same custom ribbon panel from two seperate add-ins.
Message 1 of 11
I used the code below to create a new ribbon panel
panel = assembleTab.RibbonPanels.Add("Button Name", "oNewButton", "m_ClientID")
I'm confused =how the clientID works, I assumed if they matched it would know it's the same panel. I'm try to get two different add-ins to add buttons to the same custom ribbon panel. Any ideas?
Replies (10)
Message 2 of 11
Access the panel with its internal name. You have to add the panel creation code to both addinns because if one loads first with out panel creation will not work. see the example below which will help you. I used the panel creation code in more than one Addin
Dim Multi_Body_Panel As Inventor.RibbonPanel
                    Try
                        Multi_Body_Panel = oPart_AddInTab.RibbonPanels("id_PanelP_Multi-Body")
                    Catch ex As Exception
                        Multi_Body_Panel = oPart_AddInTab.RibbonPanels.Add("Multi-Body", _
        "id_PanelP_Multi-Body", ThisGuidString, , )
                    End Try
                    Multi_Body_Panel.CommandControls.AddButton(Rename_Solid_BtnDef, True, True, , )
Message 3 of 11
What does the GUID need to be? Match the add-in that it is in or make them the same? I did both ways and it creates two of the same named panel. I can't get it to reuse the other.
Message 4 of 11
GUID is the ClientID of the Addin. use the "Try :Catch :End Try" to check the ribbon is available if not create it. if this is added to both the addins the ribbon will be created once for the first loaded addin and the second addin will use the existing Ribbon.
Message 5 of 11
philippe.leefsma
Hi Thomas,
Philippe Leefsma
Developer Technical Services
Autodesk Developer Network
Message 6 of 11
Ok, I think I'm getting closer. Now it doesn't create two panels but it fails to add the 2nd add-ins button to the panel even though it does elsewhere and is loading and running ok. Here's my code:
                Try
                Dim oPanel As Inventor.RibbonPanel
                    oPanel = DWGToolsTab.RibbonPanels.Item("id_RibbonTab")
                End Try
            If oPanel Is Nothing Then
                oPanel = DWGToolsTab.RibbonPanels.Add("Panel Name", "id_RibbonTab", "{GUID}")
            End If
            Try
                '## Add the button to the panel
                oPanel.CommandControls.AddButton(m_ButtonDefinition, True)
            End Try
Message 7 of 11
philippe.leefsma
Works perfectly on my side, take a look at the attached project ...
Testing under 2014
Philippe Leefsma
Message 8 of 11
Try modifying as below
 Try
                End Try
Message 9 of 11
I think the single line of code method was the trick, this worked:
            Try
                panel = m_inventorApplication.UserInterfaceManager.Ribbons("Part").RibbonTabs("id_TabTools").RibbonPanels("id_ADNTab")
                panel = m_inventorApplication.UserInterfaceManager.Ribbons("Part").RibbonTabs("id_TabTools").RibbonPanels.Add( _
                   "ADN Tab", "id_ADNTab", clientId)
            End Try
Thank you both for all your help!
Message 10 of 11
It doesn’t matter whether you put the code in single line or split with declarations. It matters where you write the code. The declaration (dim) statement should be outside (before) the “try” block then only it will be taken by the code under “catch” block.
Message 11 of 11
VdVeek
Is the order in which Add-In is loading first determinative in which order the buttons will show up in the Ribbon panel?
Rob.
Autodesk Inventor 2015 Certified Professional & Autodesk Inventor 2012 Certified Professional.
