Adding and constraining components in assembly
tomislav.peran
tomislav.peran
So maybe it is better for something like this to use Factory Design add-in but I do not really like using that in 3D so I am trying to use the rule written below as a substitute for here and there.
In the same folder, I have my assy named "My Assy" and the component that I want to add, named "Cube".
Firstly Cube:1 is added and constrained in the correct place, then I start the code.
By using the code new cubes are added and the constraint "insert" is automatically activated (also with a locked rotation so no additional constraints are needed).
My problem is that I want to use a named entity when adding a constraint. The named entity is an edge that is defined in a Cube. Second edge I pick myself (one of the holes).
Since new cubes are added I think this code does not understand that it needs to pick a named entity from the last Cube that is added. But I am guessing here being a starter with this coding.
If anyone knows how to solve this please let me know.
Dim oAsm As AssemblyDocument = ThisDoc.Document
Dim oDoc As PartDocument
Dim oPath As String
oPath = ThisDoc.Path
Dim oName As String
oName = "Cube.ipt"
oDoc = ThisApplication.Documents.Open(oPath & "\" & oName, False)
oDoc.Close
Try
i = oAsm.ComponentDefinition.Occurrences.AllReferencedOccurrences(oDoc).Count + 1
Catch
i = 1
End Try
While True
Dim componentA = Components.Add("Cube:" & i, oPath & "\" & oName, position := Nothing, grounded := False, visible := True, appearance := Nothing)
Dim iLogicAuto = iLogicVb.Automation
Dim namedEntities = iLogicAuto.GetNamedEntities(oDoc)
Dim oEdge1 As Edge = namedEntities.FindEntity("My Edge")
Dim oEdge2 As Edge = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kPublicationEdgeFilter, "Pick second edge. press Esc to cancel")
If oEdge2 Is Nothing Then Exit Sub
oAsm.ComponentDefinition.Constraints.AddInsertConstraint2(oEdge1,oEdge2,True,0,True)
oAsm.Update
	i = i + 1
End While
dalton98
How I would go about it is naming every face/edge geometry like you did with "My Edge". Then you could use the pick tool in the assembly to retrieve that geometry to make a constraint.
Dim oFace As FaceProxy = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kPartFaceFilter, "select face")
Dim oFace1 As Face
oFace1 = oFace.NativeObject
Dim component2 As String = oFace.Parent.Parent.Name
Dim component2entity As String = oFace1.AttributeSets.Item("iLogicEntityNameSet").Item("iLogicEntityName").Value
Constraints.AddMate("Mate1", "cube:1", "Face0", component2, component2entity)
Curtis_Waguespack
Hi @tomislav.peran
See this link for something similar that might give you some ideas. There is a zip file with a simple data set in that post:
https://forums.autodesk.com/t5/inventor-ilogic-and-vb-net-forum/place-component-gt-activate-insert-m...
I hope this helps.
Curtis
Curtis_Waguespack
Hi @tomislav.peran,
After I posted the previous link, I started to think about some of the specifics, so I took a few minutes to update the data set at that link to match your example.
Here is an Inventor 2022 version of this for you to look at (see the rule called Rule0 in the assembly file):
2022 Place and Constraint Cubes.zip
I hope this helps.
Curtis
And here's the code in case it helps someone in a future search:
Imports System.Text.RegularExpressions
Dim oDoc As AssemblyDocument
oDoc = ThisDoc.Document
Dim oCubeFile = "Cube.ipt"
Dim oCubeOccPrefix = "Cube:"
Dim oEdgePrefix = "InsertEdge_"
i = 0
'count existing cubes, if any
For Each oOcc In oDoc.ComponentDefinition.Occurrences
	If oOcc.name.contains(oCubeOccPrefix) Then
		oOcc.Name = oCubeOccPrefix & "---" & i 'set temp name
		i = i + 1
	End If
Next
i = 1
'renumber
		oOcc.Name = oCubeOccPrefix & i 'set  name
		i = i + 1
	End If
Next
Dim oEdge As Edge
While True
	oEdge = ThisApplication.CommandManager.Pick(
	SelectionFilterEnum.kPartEdgeCircularFilter,
	"Select an insert edge")
	' If nothing gets selected then we're done
	If IsNothing(oEdge) Then Exit While
	Dim oCube = Component.InventorComponent(oEdge.Parent.Parent.name)
	Dim oNamedEntities = iLogicAuto.GetNamedEntities(oCube.Definition.Document)
	'get or set existing cube insert edge name
	Try
		oName = oNamedEntities.GetName(oEdge)
	Catch
	End Try
	oEdgeName = oName
	If oEdgeName = "" Then
		TryAgain :
		'create new name using date & time
		oNow = oEdgePrefix & Now()
		oEdgeName = Regex.Replace(oNow, "[:/ ]", String.Empty)
		If oNamedEntities.NameExists(oEdgeName) Then
			GoTo TryAgain
		Else
			oNamedEntities.SetName(oEdge, oEdgeName)
		End If
	End If
	'Insert new
	Dim oNewCube = Components.Add(oCubeOccPrefix & i, oCubeFile)
	'constriants
	Constraints.AddInsert("CubeInsert:" & i,
	oNewCube, "Protrusion_Edge",
	oCube.Name,	oEdgeName, axesOpposed := True)
	Constraints.AddFlush("CubeFlush:" & i,
	oNewCube, "XZ Plane",
	oCube.Name,	"XZ Plane")
	InventorVb.DocumentUpdate()
	i = i + 1
'	ThisApplication.ActiveView.Fit
End While
tomislav.peran
Thanks a lot, guys! I will look at it tommorow when I get access to Inventor.
In the video, the code does exactly what I had in mind. 🙂
tomislav.peran
Hi Curtis,
It has been a while since I posted this question but I have opened recently this rule and I am wondering about one thing.
In the following part of the code is it necessary to start with i=0 ? Would not result be the same if we started with i=1 immediately?
i = 0
		i = i + 1
	End If
Next
i = 1
'renumber
		i = i + 1
	End If
Next
Tom
