- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I have gone through the API help page on Inventor 2018 and i cant find any examples there nor in the forum.
Basically You select a face, you place a point and you can make that point a hole, that is fine.
But that centre-point is not constrained with dimensions towards the edges of that particular face.
how can I just add a dimension by code, either by ilogic or VBA?
The API help page talks about geometric constraints but a not adding a dimension.
You can see the point is unconstrained ( green)
I want to add to dimensions towards the referenced edges of that face.
pretty simple right?
Please see that attached part with Rule 1 in ilogic.
