Thanks for providing your code which profoundly inspired me to overcome some obstacles. However, I developed my own code. This is the most sophisticated code I have written
Public GOccName As String
Sub main()
Call AddBalloon("E", "W04_Outer", 2, 2, 0.5)
'Call AddBalloon("E", "BlowPipe_01", -1, -1, 0.5)
' This does not work because it is a pipe projected in the drawing (Balloon 'item No.28) as shown in the figure in the post
End Sub
Sub AddBalloon(viewName As String, AttributeName As String, x As Double, y As Double, intent As Double)
'Reference the drwing file A8-003 that must be open
If ThisApplication.ActiveDocument.DocumentType <> _
DocumentTypeEnum.kDrawingDocumentObject Then
Call MsgBox("The drawing document is Not active." _
& " Please Activate it first", vbOKOnly, "Document Type")
Exit Sub
Else
Dim oDrawDoc As DrawingDocument
Set oDrawDoc = ThisApplication.ActiveDocument
'Reference the active Sheet must be NO.1
If oDrawDoc.DisplayName <> "1Fxxx-A8-0x.dwg" Then
Call MsgBox(" You need to open A8-003 Drawing", vbCritical, "Drawing file")
Else
Dim oSheet As Sheet
Set oSheet = oDrawDoc.Sheets.Item(1)
'Reference the View we want
Dim sViewName As String
sViewName = viewName
For i = 1 To oSheet.DrawingViews.Count
If oSheet.DrawingViews.Item(i).Name = viewName Then
Dim oView As DrawingView
Set oView = oSheet.DrawingViews.Item(i)
Next
If oView Is Nothing Then
Call MsgBox("View named " & sViewName & " was not found. Exiting.", vbCritical, "Drawing View")
Exit Sub
ElseIf oView.Suppressed = True Then
oView.Suppressed = False
Exit Sub
'Reference the Model on that Sheet
Dim oAssemblyDoc As Document
Set oAssemblyDoc = oView.ReferencedDocumentDescriptor.ReferencedDocument
'Find the assigned Attribute on an Object
Dim sAttributeSetName As String
Dim sAttributeName As String
sAttributeSetName = "Balloon"
sAttributeName = AttributeName
Dim oObjs As ObjectCollection
Set oObjs = oAssemblyDoc.AttributeManager _
.FindObjects(sAttributeSetName, sAttributeName)
If oObjs.Count = 0 Then
Call MsgBox("attribute name " & sAttributeName & _
" was not found. Exiting.", vbCritical, "Attribute object")
Exit Sub
' get the face of the object
Dim oTypeName As String
oTypeName = TypeName(oObjs.Item(1))
Dim oFace As Face
Dim oFaceProxy As FaceProxy
Dim oOccName As String
If oTypeName = "Face" Then
Set oFace = oObjs.Item(1)
oOccName = oFace.ContainingOccurrence.Name
ElseIf oTypeName = "FaceProxy" Then
Set oFaceProxy = oObjs.Item(1)
oOccName = oFaceProxy.ContainingOccurrence.Name
Else
Call MsgBox("the assigned object's Face was Not found. Exiting", vbCritical, "Face")
Exit Sub
GOccName = oOccName
' get the occurrence of the detected face
Dim Oocc As ComponentOccurrence
Set Oocc = OccSearch(oAssemblyDoc)
If Oocc Is Nothing Then
Call MsgBox("the Occurrence of the detected object is Not found. Exiting", vbCritical, "Occurrence")
Exit Sub
Dim oParentOcc As ComponentOccurrence
Set oParentOcc = Oocc.ParentOccurrence
Call Oocc.CreateGeometryProxy(oFace, oFaceProxy)
If Not oParentOcc Is Nothing Then
Call oParentOcc.CreateGeometryProxy(oFace, oFaceProxy)
'Promote to an DrawingCurve on the View
Dim oViewAllCurves As DrawingCurvesEnumerator
Dim oViewCurves As DrawingCurvesEnumerator
Set oViewAllCurves = oView.DrawingCurves
For i = 1 To oViewAllCurves.Count
If oViewAllCurves.Item(i).StartPoint Is Nothing Or _
oViewAllCurves.Item(i).Evaluator3D Is Nothing Or _
oViewAllCurves.Item(i).ModelGeometry Is Nothing Then
i = i + 1
Else
If oViewAllCurves.Item(i).ModelGeometry.ContainingOccurrence.Name = oOccName Then
Set oViewCurves = oView.DrawingCurves(oFaceProxy)
Exit For
Next
If oViewCurves Is Nothing Then
Call MsgBox("Occurrence does not belong to the view. Exiting", vbExclamation, "View Refrence Documents")
Exit Sub
If oViewCurves.Count = 0 Then
Call MsgBox("No curves found in view. Exiting", vbExclamation, "Drawing Curves")
Exit Sub
Dim ocurve As DrawingCurve
Set ocurve = oViewCurves.Item(1)
' locate a text point for the Balloon relative to the assigned curve
Dim oMidPoint As Point2d
Set oMidPoint = ocurve.MidPoint
Dim oTG As TransientGeometry
Set oTG = ThisApplication.TransientGeometry
Dim Xpos As Double
Dim Ypos As Double
Xpos = oMidPoint.x + x
Ypos = oMidPoint.y + y
Set oPoint = oTG.CreatePoint2d(Xpos, Ypos)
' Attach Balloon to the text point
Dim oLeaderPoint As ObjectCollection
Set oLeaderPoint = ThisApplication.TransientObjects _
.CreateObjectCollection
Call oLeaderPoint.Add(oPoint)
' locate a leader point for the Balloon
Dim GI As GeometryIntent
Set GI = oSheet.CreateGeometryIntent(ocurve, intent)
Call oLeaderPoint.Add(GI)
' Deleting the dublicated Balloon if any
Dim K As Integer
K = oSheet.Balloons.Count ' Number of Balloons
Dim counter As Integer
counter = 0 ' Number of similar balloons
For i = 1 To K
While i < K
If oSheet.Balloons.Item(i).ParentView.Name = sViewName Then
If oSheet.Balloons.Item(i).Position.x = Xpos And _
oSheet.Balloons.Item(i).Position.y = Ypos Then
oSheet.Balloons.Item(i).Delete
K = K - 1
i = i + 1
Wend
Next
' Adding the Balloon
Dim oBalloon As Balloon
Set oBalloon = oSheet.Balloons.Add(oLeaderPoint)
' Deleting previously exsited balloon if any
Dim oBalloonItemNumber As String
oBalloonItemNumber = oBalloon.BalloonValueSets _
.Item(1).ItemNumber
K = oSheet.Balloons.Count ' Updated Number of Balloons
For i = 1 To K
While i < K
If oSheet.Balloons.Item(i).ParentView.Name = sViewName _
And oSheet.Balloons.Item(i).BalloonValueSets _
.Item(1).ItemNumber = oBalloonItemNumber _
And oSheet.Balloons.Item(i).Position.x <> Xpos And _
oSheet.Balloons.Item(i).Position.y <> Ypos Then
counter = counter + 1
If counter >= 1 Then
K = K - 1
i = i - 1
i = i + 1
Wend
Next
End Sub
Function OccSearch(AssemblyDoc As AssemblyDocument) As ComponentOccurrence
Dim CompName As String
For Each SubCompOcc In AssemblyDoc.ComponentDefinition.Occurrences
CompName = SubCompOcc.Name
If CompName = GOccName Then
Set OccSearch = SubCompOcc
Exit Function
If SubCompOcc.Visible = True And _
SubCompOcc.Suppressed = False And _
SubCompOcc.BOMStructure = kNormalBOMStructure And _
SubCompOcc.DefinitionDocumentType = kAssemblyDocumentObject Then
'MsgBox "ATTWNTION"
Set OccSearch = OccSearch(SubCompOcc.Definition.Document)
If Not OccSearch Is Nothing Then
Exit Function
Next
Set OccSearch = Nothing
End Function
so far that I wanted to share with you to even develop it further. Thanks to @WCrihfield
