Adding a Balloon using VBA
mostafamahmoudseddek94
Message 1 of 8
I have an assembly with an attribute as shown
 I want to add a balloon (No. 20) on a specific view  ( detail E) automatically as shown
I am developing a code in VBA but got stuck when I try to execute the following line
 Set oViewCurves = oView.DrawingCurves(oFaceProxy)
the error message that appears says Method 'DrawingCurves' of object "DetailDrawingView" failed
Here is my code to suggest for me an amendment
Sub Balloons()
'Reference the file that's open
Dim oDrawDoc As DrawingDocument
Set oDrawDoc = ThisApplication.ActiveDocument
'Reference the active Sheet
Dim oSheet As Sheet
Set oSheet = oDrawDoc.Sheets.Item(1)
'Reference the View we want
For i = 1 To oSheet.DrawingViews.Count
    If oSheet.DrawingViews.Item(i).Name = "E" Then
        Dim oView As DrawingView
        Set oView = oSheet.DrawingViews.Item(i)
    End If
Next
'Reference the Asembly Model on that Sheet
Dim oAssemblyDoc As Document
Set oAssemblyDoc = oView.ReferencedDocumentDescriptor.ReferencedDocument
Dim oTG As TransientGeometry
Set oTG = ThisApplication.TransientGeometry
'reference the assigned attribute on the Assembly Model
Dim oMainObjs As ObjectCollection
Set oMainObjs = oAssemblyDoc.AttributeManager.FindObjects("Balloon", "W01_Outer")
'reference to the Occerrence of tha Assembly Model
Dim oOcc As ComponentOccurrence
Set oOcc = oAssemblyDoc.ComponentDefinition.Occurrences.ItemByName(oMainObjs.Item(1).ContainingOccurrence.Name)
'reference to the Wanted Face
Dim oFace As Face
Set oFace = oMainObjs.Item(1)
'Promote to Proxy Face
Dim oFaceProxy As Inventor.FaceProxy
Call oOcc.CreateGeometryProxy(oFace, oFaceProxy)
'Promote to an DrawingCurve on the View
Dim oCurves As DrawingCurve
Set oCurves = oViewCurves.Item(1)
End Sub
Replies (7)
Message 2 of 8
WCrihfield
Hi @mostafamahmoudseddek94.  Retrieving named geometry to work with in a drawing from a multi-level assembly, can definitely be challenging.  Especially when it may be down one or more levels below the top level of the assembly.  I added quite a bit of code to your VBA macro to help debug where something might be going wrong.  I also added a custom recursive component search function at the end.  I don't know if this will fix all your problems or not, but it's probably at least a pretty good start in that direction.  You could review this code first, then give it a try if you want.
Sub Balloons()
    Dim oSheet As Sheet
    Dim oEView As DrawingView
    For Each oView In oSheet.DrawingViews
        If oView.Name = "E" Then
            Set oEView = oView
        End If
    Next
    If oEView Is Nothing Then
        Call MsgBox("View named 'E' not found. Exiting.", vbCritical, "")
        Exit Sub
    End If
    If oMainObjs.Count = 0 Then
        Call MsgBox("Named geometry for balloon not found. Exiting.", vbCritical, "")
        Exit Sub
    End If
    'check Type of 1st object (is it Face or FaceProxy)
    Dim oObj1 As Object
    Set oObj1 = oMainObjs.Item(1)
    Dim oTypeName As String
    oTypeName = TypeName(oObj1)
    Call MsgBox("The TypeName of the first found object = " & oTypeName, vbInformation, "")
    Dim oFace As Face
    Dim oFaceProxy As FaceProxy
    If oTypeName = "Face" Then
        Set oFace = oObj1
    ElseIf oTypeName = "FaceProxy" Then
        Set oFaceProxy = oObj1
    Else
        Exit Sub
    End If
    If oFace Is Nothing And oFaceProxy Is Nothing Then Exit Sub
    If oFace Is Nothing And oFaceProxy Is Not Nothing Then GoTo GetDCurves
    'get ComponentDefinition from oFace
    Dim oCD As ComponentDefinition
    Set oCD = oFace.SurfaceBody.ComponentDefinition
    'find the (or a) component that represents this oCD
    Dim oContainingOcc As ComponentOccurrence
    Set oContainingOcc = RecusiveComponentSearch(oAssemblyDoc.ComponentDefinition.Occurrences, oCD)
    If oContainingOcc Is Nothing Then Exit Sub
    Dim oParentOcc As ComponentOccurrence
    'this assumes the containing occurrence was on second level
    'and assumes this parent occurrence is on the top level
    Set oParentOcc = oContainingOcc.ParentOccurrence
    Call oParentOcc.CreateGeometryProxy(oFace, oFaceProxy)
GetDCurves:
    Dim oViewCurves As DrawingCurvesEnumerator
    If oViewCurves.Count = 0 Then
        Call MsgBox("No curves found in view.", vbExclamation, "")
        Exit Sub
    End If
    Dim oDCurve As DrawingCurve
    Set oDCurve = oViewCurves.Item(1)
    Call MsgBox("Got the drawing curve.", vbInformation, "")
End Sub
Function RecusiveComponentSearch(oComps As ComponentOccurrences, oCompDef As ComponentDefinition) As ComponentOccurrence
    Dim oTartetComp As ComponentOccurrence
    Dim oComp As ComponentOccurrence
    For Each oComp In oComps
        If oComp.Definition Is oCompDef Then
            RecusiveComponentSearch = oComp
            Exit Function
        End If
        If oComp.DefinitionDocumentType = kAssemblyDocumentObject Then
            RecusiveComponentSearch = RecusiveComponentSearch(oComp.Definition.Occurrences, oCompDef)
            If Not RecusiveComponentSearch Is Nothing Then
                Exit Function
            End If
        End If
    Next
    RecusiveComponentSearch = Nothing
End Function
If this solved your problem, or answered your question, please click ACCEPT SOLUTION.
Or, if this helped you, please click (LIKE or KUDOS) 👍.
If you want and have time, I would appreciate your Vote(s) for My IDEAS :bulb: or you can Explore My CONTRIBUTIONS
Wesley Crihfield
(Not an Autodesk Employee)
Message 3 of 8
Hi, Thanks for your code which inspired me to develop and complete mine. I have a problem getting drawing curves for balloon item number 28 since it is a cylinder oDrawingCurves(oFaceProxy) that has no items.
what is the change should I apply to get a drawing curve regardless of the type of curve itself?
Message 4 of 8
JelteDeJong
I have written some blog post about generating dimensions (using attributes) in assembly drawings. The most important thing is probably getting the intent. I guess that you also need to find an intent to attach the ballons at. You might want to check the post "Add function "GetProxyIntent()" to Ilogic". You also might want to check out the other articles in that serie.
Jelte de Jong
Blog: hjalte.nl - github.com
Message 5 of 8
The link is not working. May you provide me with another one?
I do not have an idea to get a drawing edge of a circular (cylindrical object), and I am highly interested to read your articles
Message 6 of 8
Thanks for providing your code which profoundly inspired me to overcome some obstacles. However, I developed my own code. This is the most sophisticated code I have written
Public GOccName As String
Sub main()
Call AddBalloon("E", "W04_Outer", 2, 2, 0.5)
'Call AddBalloon("E", "BlowPipe_01", -1, -1, 0.5)
' This does not work because it is a pipe projected in the drawing (Balloon 'item No.28) as shown in the figure in the post
End Sub
Sub AddBalloon(viewName As String, AttributeName As String, x As Double, y As Double, intent As Double)
'Reference the drwing file A8-003 that must be open
If ThisApplication.ActiveDocument.DocumentType <> _
   DocumentTypeEnum.kDrawingDocumentObject Then
   Call MsgBox("The drawing document is Not active." _
  & " Please Activate it first", vbOKOnly, "Document Type")
   Exit Sub
Else
End If
'Reference the active Sheet must be NO.1
If oDrawDoc.DisplayName <> "1Fxxx-A8-0x.dwg" Then
    Call MsgBox(" You need to open A8-003 Drawing", vbCritical, "Drawing file")
Else
    Dim oSheet As Sheet
End If
Dim sViewName As String
    sViewName = viewName
    If oSheet.DrawingViews.Item(i).Name = viewName Then
    End If
Next
If oView Is Nothing Then
    Call MsgBox("View named " & sViewName & " was not found. Exiting.", vbCritical, "Drawing View")
    Exit Sub
    ElseIf oView.Suppressed = True Then
    oView.Suppressed = False
    Exit Sub
End If
'Reference the Model on that Sheet
'Find the assigned Attribute on an Object
Dim sAttributeSetName As String
Dim sAttributeName As String
sAttributeSetName = "Balloon"
sAttributeName = AttributeName
Dim oObjs As ObjectCollection
Set oObjs = oAssemblyDoc.AttributeManager _
.FindObjects(sAttributeSetName, sAttributeName)
If oObjs.Count = 0 Then
    Call MsgBox("attribute name " & sAttributeName & _
    " was not found. Exiting.", vbCritical, "Attribute object")
    Exit Sub
End If
' get the face of the object
    oTypeName = TypeName(oObjs.Item(1))
Dim oFace As Face
Dim oOccName As String
    Set oFace = oObjs.Item(1)
    oOccName = oFace.ContainingOccurrence.Name
    Set oFaceProxy = oObjs.Item(1)
    oOccName = oFaceProxy.ContainingOccurrence.Name
Else
    Call MsgBox("the assigned object's Face was Not found. Exiting", vbCritical, "Face")
    Exit Sub
End If
GOccName = oOccName
' get the occurrence of the detected face
Dim Oocc As ComponentOccurrence
Set Oocc = OccSearch(oAssemblyDoc)
If Oocc Is Nothing Then
    Call MsgBox("the Occurrence of the detected object is Not found. Exiting", vbCritical, "Occurrence")
    Exit Sub
End If
Set oParentOcc = Oocc.ParentOccurrence
    Call Oocc.CreateGeometryProxy(oFace, oFaceProxy)
        If Not oParentOcc Is Nothing Then
        End If
End If
Dim oViewAllCurves As DrawingCurvesEnumerator
Set oViewAllCurves = oView.DrawingCurves
For i = 1 To oViewAllCurves.Count
    If oViewAllCurves.Item(i).StartPoint Is Nothing Or _
        oViewAllCurves.Item(i).Evaluator3D Is Nothing Or _
        oViewAllCurves.Item(i).ModelGeometry Is Nothing Then
    i = i + 1
    Else
        If oViewAllCurves.Item(i).ModelGeometry.ContainingOccurrence.Name = oOccName Then
            Exit For
        End If
    End If
Next
If oViewCurves Is Nothing Then
    Call MsgBox("Occurrence does not belong to the view. Exiting", vbExclamation, "View Refrence Documents")
    Exit Sub
End If
    Call MsgBox("No curves found in view. Exiting", vbExclamation, "Drawing Curves")
    Exit Sub
End If
Dim ocurve As DrawingCurve
Set ocurve = oViewCurves.Item(1)
' locate a text point for the Balloon relative to the assigned curve
Dim oMidPoint As Point2d
Set oMidPoint = ocurve.MidPoint
Dim Xpos As Double
Dim Ypos As Double
Xpos = oMidPoint.x + x
Ypos = oMidPoint.y + y
Set oPoint = oTG.CreatePoint2d(Xpos, Ypos)
' Attach Balloon to the text point
Dim oLeaderPoint As ObjectCollection
Set oLeaderPoint = ThisApplication.TransientObjects _
.CreateObjectCollection
Call oLeaderPoint.Add(oPoint)
' locate a leader point for the Balloon
Dim GI As GeometryIntent
Set GI = oSheet.CreateGeometryIntent(ocurve, intent)
Call oLeaderPoint.Add(GI)
' Deleting the dublicated Balloon if any
Dim K As Integer
    K = oSheet.Balloons.Count ' Number of Balloons
Dim counter As Integer
    counter = 0 ' Number of similar balloons
For i = 1 To K
    While i < K
        If oSheet.Balloons.Item(i).ParentView.Name = sViewName Then
            If oSheet.Balloons.Item(i).Position.x = Xpos And _
               oSheet.Balloons.Item(i).Position.y = Ypos Then
               oSheet.Balloons.Item(i).Delete
               K = K - 1
            End If
        End If
      i = i + 1
    Wend
Next
' Adding the Balloon
Dim oBalloon As Balloon
Set oBalloon = oSheet.Balloons.Add(oLeaderPoint)
' Deleting previously exsited balloon if any
Dim oBalloonItemNumber As String
    oBalloonItemNumber = oBalloon.BalloonValueSets _
    .Item(1).ItemNumber
K = oSheet.Balloons.Count ' Updated Number of Balloons
For i = 1 To K
    While i < K
        If oSheet.Balloons.Item(i).ParentView.Name = sViewName _
        And oSheet.Balloons.Item(i).BalloonValueSets _
            .Item(1).ItemNumber = oBalloonItemNumber _
            And oSheet.Balloons.Item(i).Position.x <> Xpos And _
                        oSheet.Balloons.Item(i).Position.y <> Ypos Then
                counter = counter + 1
            If counter >= 1 Then
                K = K - 1
                i = i - 1
            End If
        End If
      i = i + 1
    Wend
Next
End Sub
Function OccSearch(AssemblyDoc As AssemblyDocument) As ComponentOccurrence
Dim CompName As String
For Each SubCompOcc In AssemblyDoc.ComponentDefinition.Occurrences
     CompName = SubCompOcc.Name
    If CompName = GOccName Then
        Set OccSearch = SubCompOcc
         Exit Function
    End If
    If SubCompOcc.Visible = True And _
        SubCompOcc.Suppressed = False And _
        SubCompOcc.BOMStructure = kNormalBOMStructure And _
        SubCompOcc.DefinitionDocumentType = kAssemblyDocumentObject Then
            'MsgBox "ATTWNTION"
            Set OccSearch = OccSearch(SubCompOcc.Definition.Document)
            If Not OccSearch Is Nothing Then
                Exit Function
            End If
    End If
Next
Set OccSearch = Nothing
End Function
so far that I wanted to share with you to even develop it further. Thanks to @WCrihfield
Message 7 of 8
WCrihfield
Hi @mostafamahmoudseddek94.  I don't know if the code in your last post is working for you yet, but I'm betting not.  When quickly looking it over this morning I saw something that is most likely a problem/mistake.  Within your 'AddBalloon' sub routine, at the point you are attempting to get the DrawingView object, you are declaring your oView variable, and setting its value, all within both a For...Next block, and within a If...Then block.  In order to retain that variable and its value, you must at least declare the variable before, and outside of those two blocks of code.  It's OK to set its value within those blocks though.  When you declare a variable within a lower level block of code, it only exists within that lower level block of code, and does not exist at the higher level block of code.  So, the following block of code that is checking 'If oView is Nothing' will likely always be True, until you fix that.  Also, I noticed that you created a new variable called 'sViewName' just before this point.  That is totally unnecessary.  You could just delete that, then in the message following the 'oView Is Nothing' check, replace 'sViewName' variable with the original 'viewName' variable.  Just a couple quick thoughts.
Wesley Crihfield
Message 8 of 8
This is the Code to add a balloon using VBA with the Attribute helper.
Sub AddBalloon(SheetNo As Double, viewName As String, AttributeName As String _
                , xPosition As Double, yPosition As Double, intent As Double)
' 1- Reference the drwing file A8-003 that must be open specifically
   BCheck = False
   Exit Sub
Else
End If
' 2- Reference the active Sheet
    BCheck = False
   Exit Sub
Else
    Dim oSheet As Sheet
    Set oSheet = oDrawDoc.Sheets.Item(SheetNo)
End If
' 3- Reference the needed drwing View
    End If
Next
'Verify that the selected drawing view exist, and not suppressed.
    Call MsgBox("View named (" & viewName & ") was not found. Exiting.", vbCritical, "Drawing View")
    BCheck = False
    Exit Sub
    BCheck = False
    Exit Sub
End If
' 4- Reference the Model on that Sheet
'Verify that the selected drawing view is of an assembly.
If oAssemblyDoc.DocumentType <> kAssemblyDocumentObject Then
    Call MsgBox("The selected View must be of an assembly", vbInformation, "Document Type")
    BCheck = False
    Exit Sub
End If
' 5- Find the assigned Attribute of an Object
' Verify the existance of the assigned attribute
   BCheck = False
   Exit Sub
End If
' 6- get the needed face of the object
Dim oFace As Face
Else
    BCheck = False
    Exit Sub
End If
GOccName = oOccName
' 7- get the occurrence of the detected object's face
' Verify the existance of the assigned occurrence
    BCheck = False
    Exit Sub
End If
    End If
End If
' 8- Promote to an DrawingCurve on the View
        i = i + 1
    Else
            If oViewCurves.Count <> 0 Then
               Exit For
            Else
                Set ocurve = oViewAllCurves.Item(i)
                Exit For
            End If
        End If
    End If
Next
' Verify the existance of the assigned Curve
If ocurve Is Nothing Then
    BCheck = False
    Exit Sub
End If
If oViewAllCurves.Count = 0 Then
    BCheck = False
    Exit Sub
End If
' 9- locate a position for the text point of the Balloon
' this will be relative to the assigned curve
Dim Xpos As Double
Dim Ypos As Double
Xpos = oMidPoint.x + xPosition
Ypos = oMidPoint.y + yPosition
' 10- locate a leader point for the Balloon
Dim K As Integer
For i = 1 To K
    While i < K
               K = K - 1
            End If
        End If
      i = i + 1
    Wend
Next
    .Item(1).ItemNumber
For i = 1 To K
    While i < K
                K = K - 1
                i = i - 1
            End If
        End If
      i = i + 1
    Wend
Next
   BCheck = True
End Sub
         Exit Function
    End If
                Exit Function
            End If
    End If
Next
End Function
I hope everyone finds it useful.
