Addin .net version and iLogic.Interfaces.
awatt
Message 1 of 9
awatt
I've attempted to convert an addin from 2018 to 2020. It's been a nightmare.
(visual studio 2019)
I believe some of the problem is .net framework version.  The template sets it to v4.5, but the Autodesk.iLogic.Interfaces.dll is version 24.0.16800 and needs .net 4.7.  I've tried raising the .net version of the project, but the final addin won't load.
What to do?
(and a small vent - I find the Inventor version / VS version / .net version situation would best be described as slapstick if only it didn't have such a measurable negative impact on my productivity.)
Accepted solutions (3)
Replies (8)
Message 2 of 9
Martin-Winkler-Consulting
@awatt
Use .Net Framework 4.7.2 or higher.
https://support.microsoft.com/de-de/help/4503548/microsoft-net-framework-4-8-offline-installer-for-w...
If that doesn't help, please give more information.
Martin Winkler
CAD Developer
Did you find this post helpful? Feel free to like this post.
Message 3 of 9
etaCAD
Did you check in the debugger at which position the loading of your add-in stops?
Maybe there is also a peoblem with your .addin file when you changed to another version of Inventor.
Andreas
etaCAD
Message 4 of 9
awatt
Is that possible with the freebie VS?
I attached to the inventor.exe process, but I don't see anything happen in the 'diagnostic tools' when I attempt to reload the addin.
Message 5 of 9
@awatt
Yes debugging is possible.
Could you upload the .addin file?
Martin Winkler
CAD Developer
Message 6 of 9
awatt
I'm not sure if the last message made it through. . .
Message 7 of 9
awatt
I think my greatest sin is the .dll file contains spaces and hyphens, while the .addin file replaces those characters with underscore.
Message 8 of 9
<Addin Type="Standard">
  <!--Created for Autodesk Inventor Version 24.0-->
  <ClassId>{c4ce4c3b-1542-45c3-96c0-3c4e3bdefca0}</ClassId>
  <ClientId>{c4ce4c3b-1542-45c3-96c0-3c4e3bdefca0}</ClientId>
  <DisplayName>Vac_Con_Inventor_2020_addin</DisplayName>
  <Description>Vac_Con_Inventor_2020_addin</Description>
  <Assembly>Vac_Con_Inventor_2020_addin.dll</Assembly>
  <LoadOnStartUp>1</LoadOnStartUp>
  <UserUnloadable>1</UserUnloadable>
  <Hidden>0</Hidden>
  <SupportedSoftwareVersionGreaterThan>23..</SupportedSoftwareVersionGreaterThan>
  <DataVersion>1</DataVersion>
  <UserInterfaceVersion>1</UserInterfaceVersion>
</Addin>
Where is the Vac-Con Inventor 2020 addin.dll located?
Try a full path in Line
C:/ProgramData/Autodesk/ApplicationPlugins/Vac-Con Inventor 2020 addin.dll
and save the dll to this path
Rename Autodesk.Vac-Con Inventor 2020 addin.Inventor.addin to Vac-Con Inventor 2020.addin and save it also to the path: C:\ProgramData\Autodesk\ApplicationPlugins
Martin Winkler
CAD Developer
Message 9 of 9
etaCAD
With Visual Studio 2019 you can easily debug when you add Inventor.exe to the external program in the Debug-tab in your project settings. You don't need to 'cheat'  anymore as with the Express versions.
Before starting the debugger you should first check with the Add-in-Manager if you app is listed and shows the correct path to your dll. If not, check and fix your .addin file. Otherwise debugging is useless because your dll will never be loaded from Inventor.
Andreas
etaCAD
