Addin help inventor 2025
Alex.Elbertse
Observer Observer
Alex.Elbertse
Observer
Observer
Relatively new to programming add-ins, but we need a custom add-in that does the following:
  1. Generate a STEP file from parts, or all parts in an assembly.
  2. Send a custom XML to a server.
  3. Perform a manufacturability check. Wait for the file to be processed, then check the XML file in the export directory. If it fails, it moves it to the failed folder; if successful, it is moved to the done folder.
  4. Get the results back into Inventor and process the results.
I would like to know if this is possible and how to start. I tried searching the forum but could not find any samples or topics about it.
Thanks in advance.
basautomationservices
100% possible. I can help you out if you like, contact me.
Contact me for custom app development info@basautomationservices.com. Follow below links to view my Inventor appstore apps.
Free apps: Smart Leader | Part Visibility Utility | Mate Origins
Paid apps: Frame Stiffener Tool | Constrain Plane Toggle | Property Editor Pro
Alex.Elbertse
Observer
Observer
Thank you for your reply. Actually, I am searching for a starting point to write the code myself.
Ah alright.
https://www.autodesk.com/support/technical/article/caas/tsarticles/ts/29mPk2V7aweIo6eLckSF1k.html
This guide explains the basics for making a plugin. From 2025, you can use .NET 8 though. There is an add-in template in the SDK.
https://help.autodesk.com/view/INVNTOR/2025/ENU/?guid=GUID-6FD7AA08-1E43-43FC-971B-5F20E56C8846
But there are some nicer ones you can find on github.
For reading/writing XML and pushing it to the server I think ChatGPT will get you 90% of the code.
Alex.Elbertse
Observer
Observer
add-in template in the SDK. If i install this from the 2025 installation. I don`t get the templates for 2025. Only the 2023, which i previously installed.
Any idea?
Most likely they havent changed, just reference the new interop assembly.
