Addin Does Not Work When Changing Target framework
Hi all,
I changed the target framework for my project from .NET Framework 2.0 to 4.0, and also changed the Inventor.exe.config file to read <supportedRuntime version="v4.0"/>
Now when I debug the ribbon tab that I am creating is nowhere to be found, but if i change back to 2.0 and debug, the ribbon tab is back...
Any ideas?
TIA,
-Ted
adam.nagy
Autodesk Support
Autodesk Support
Hi there,
Which Inventor version is it?
Did you also add the V2RuntimeActivationPolicy support?
  <startup useLegacyV2RuntimeActivationPolicy="true">
    <supportedRuntimeversion="v4.0"/>
  </startup>
Mixed managed modules using a previous .NET framework version would need this in order to be loaded.
I hope this helps.
Cheers,
Adam Nagy
Autodesk Platform Services
MattH_Work
</startup>
Where would I place this?
Regards
Matt
MattH
Product Design Collection 2026
Vault Pro 2026
adam.nagy
Autodesk Support
Autodesk Support
In Inventor.exe.config
Adam Nagy
