AddForSurface Polyline
I wish to create an Extrusion with an open profile having connected lines (polyline).
oSktech.Profiles.AddForSurface(ObjectCollection) does not seem to accept, ObjectCollection having set of lines...It accepts control points for a spline. Or it accepts just one line at a time. But that will create mulitple profiles, which I dont want. I want a single profile.
Here is the problem:
Dim oLineOne As SketchLine
oLineOne = oSketch.SketchLines.AddByTwoPoints( _
oTransGeom.CreatePoint2d(0, 0.75), _
oTransGeom.CreatePoint2d(5, 0.75))
Dim oLineTwo As SketchLine
oLineTwo = oSketch.SketchLines.AddByTwoPoints( _
oTransGeom.CreatePoint2d(5, 0.75), _
oTransGeom.CreatePoint2d(10, 0.75))
Dim oProfile As Profile = oSketch.Profiles.AddForSurface
Both are connected. If I give either of the lines to AddForSurface, Extrusion is created for the respective line. If I pass Object Collection of these two lines. Errors out. If I dont pass anything, as in case shown above, it picks first line for Extrusion and not the second one which is connected to it.
I wish to have multiple such connected line to be part of the same Profile.
In the interactive session, it is allowed and it creates a single surfacebody.
I received suggestion from Philippe.leefsam which worked fine. He suggsted to have SketchPoint at the junction points and use those to create SketchLines.
With this, I am able to create end-to-end connected lines and Surface Extrusion happens fine also.
One more thing that I observed is: if there is one incoming line and one outgoing line at a sketchpoint, the ExtrtusionSrf works fine, line in case of "L" likes two lines. But if more lines come together at a point, say like "T" case, AddForSurface is not able to create a path having all three. It just stops at one, and only one surface gets extruded.
Is there any restriction in such surface creation?
