AddBySilhouette troubles
jacofiero
jacofiero
I'm trying to use the PlanarSketch.AddBySilhouette method to project a collection of faces found with AssemblyComponentDefinition.FindUsingRay, but I get an error when trying to create the sketch entity.
Has anyone successfully implemented this method?  I can run the help file code example w/out error, but it's being used in a part document.  Is it possible this just doesn't work at the assembly level?  Forum search for AddBySilhouette pulls up absolutely nothing.  Code below.
    Dim oDoc As AssemblyDocument
    Set oDoc = ThisDocument
    Dim oACD As AssemblyComponentDefinition
    Set oACD = oDoc.ComponentDefinition
    Dim oTG As TransientGeometry
    Set oTG = ThisApplication.TransientGeometry
    Dim oSk As PlanarSketch
    Set oSk = oACD.Sketches.Item("Rotating Sketch")
    Dim oPart As ComponentOccurrence
    Dim oBody As SurfaceBody
    Dim startPt As Point
    Set startPt = oTG.CreatePoint(0, 0, 0)
    'create a vector facing the sketch from the origin
    Dim oVecPt As WorkPoint
    Set oVecPt = oACD.WorkPoints.Item("VectorPoint")
    Dim pt As Point
    Set pt = oVecPt.Point
    Dim oVec As UnitVector
    Set oVec = oTG.CreateUnitVector(pt.X, pt.Y, pt.Z)
    Dim objCol As ObjectsEnumerator
    Dim ptCol As ObjectsEnumerator
    Call oACD.FindUsingRay(startPt, oVec, 1, objCol, ptCol, False)
    Dim proxPt As Point
    Dim oFoundItem As Object
    Dim oSkEnt As SketchEntity
    Dim oFace As Face
    For Each oFoundItem In objCol
        If oFoundItem.Type = kFaceProxyObject Then
            Set oFace = oFoundItem.NativeObject
            Set proxPt = oFace.PointOnFace
' ERROR GENERATED BY THE LINE BELOW
            Set oSkEnt = oSk.AddBySilhouette(oFace, proxPt)
        End If
    Next
end Sub
My thoughts:
My use of the 'ProximityPoint' input could be blatantly wrong, I couldn't really glean its proper use from the code example.
or
Using the Face object in the method at the assembly level doesn't work (but neither does the FaceProxy object, unfortunately).
Appreciate any help.  Thanks.
wayne.brill
Try using a PlanarSketchProxy. Here is a VBA example I have:
Public Sub ProjectAssemEdge()
    ' get assembly document
    Dim asmDoc As AssemblyDocument
    Set asmDoc = ThisApplication.ActiveDocument
    ' get myHole from first part
    Dim occ1 As ComponentOccurrence
    Set occ1 = asmDoc.ComponentDefinition.Occurrences.Item(1)
    Dim partDef1 As PartComponentDefinition
    Set partDef1 = occ1.Definition
    Dim oProxyEdge As Edge
    Dim oEdge As Edge
    For Each oEdge In asmDoc.ComponentDefinition.Occurrences(1).SurfaceBodies(1).Edges
    If oEdge.CurveType = kCircleCurve Then
    Set oProxyEdge = oEdge
    End If
    Next
    ' get mySketch from second part
    Dim occ2 As ComponentOccurrence
    Set occ2 = asmDoc.ComponentDefinition.Occurrences.Item(2)
    Dim partDef2 As PartComponentDefinition
    Set partDef2 = occ2.Definition
    Dim mySketch As PlanarSketch
    Set mySketch = partDef2.Sketches.Item(1)
    Dim mySketchProxy As PlanarSketchProxy
    occ2.CreateGeometryProxy mySketch, mySketchProxy
    ' try to project edge in mySketch
    Dim projEdge As SketchEntity
    Set projEdge = mySketchProxy.AddByProjectingEntity(oProxyEdge)
End Sub
Wayne
Wayne Brill
Developer Technical Services
Autodesk Developer Network
jacofiero
Yes, that works if you're copying sketch entities between sketches in parts in an assembly, but you can't use it for projecting geometry onto a sketch in the assembly.
adam.nagy
Autodesk Support
Autodesk Support
The first thing you would need to do in such a case is check if it's possible in the user interface. 🙂
It does not seem to be. It seems that you can only project edges but not faces into the assembly sketch.
The API must have the same limitation then.
Cheers,
Adam Nagy
Autodesk Platform Services
