Add ''TYP. " to drawing dimension.
Sprocket1077
Sprocket1077
Hi.
I found this vba macro on this forum and I would like to update it a bit.
Sub Main  AddSuffix()
Dim oDoc As DrawingDocument
oDoc = ThisApplication.ActiveDocument
Dim oDim As DrawingDimension
Dim oStr As String
For Each oDim In oDoc.SelectSet
oStr = oDim.Text.FormattedText + "<br/>TYP."
oDim.Text.FormattedText = oStr
Next
End Sub
 First I would like it to start from a button on the ribbon.
Then I want it to ask : How many "TYP." do you need? so the macro should record "TYP. 2" if I answered "2" to the question.
And then, pick all dimensions you need to apply the text.
It should end with a "OK - Cancel" button.
I know it looks like a bit weird, but I'll save a lot of clicks with this.
Thanks for any help.
Curtis_Waguespack
Hi @Sprocket1077
Here's a version of this that I think will fit your requirements. Post back if not.
I hope this helps.
Curtis
oInput = InputBox("Enter number for TYP.#", "iLogic", "2")
If oInput = "" Then Return
While True
	'select the line segments
	Dim oDim As GeneralDimension
	oDim = ThisApplication.CommandManager.Pick _
		(SelectionFilterEnum.kDrawingDimensionFilter, _
		"Select dimesions to make to add TYP. " & oInput & " (press ESC To Exit selection)")
	If IsNothing(oDim) Then Exit While
	'set the segment color
	oDim.Text.FormattedText = "<br/>TYP." & oInput
End While
Sprocket1077
Thank you Curtis_W.
It works just fine.
Sprocket1077
Curtis_W
It works fine, but I would like to know if we could do some little modifications.
Could it be possible for the question :
 to appear only on the command line (bottom of screen) and not beside the cursor? (like a standard Inventor command)
Second question, instead of " (press ESC To Exit selection)", could it be possible to right click and select OK or CANCEL?
My last interrogation is, I have difficulty to transform this iLogic expression into a vba macro that will be apply to a button.  Do you have tips for this application?
Again I know that this is very particular , but at the end it will be a very nice macro.
Thank you and sorry for the complications (and my english).
Curtis_Waguespack
Hi @Sprocket1077
Unfortunately, the Pick command is pretty limited. You can set that string to just read "Select Dimensions" if you'd prefer, but it still requires an Escape to move past the selection mode.... which of course is not the most intuitive thing, so that is why I typically add that to the prompt string.
I hope this helps.
Curtis
Curtis_Waguespack
To add iLogic rules as a button, this addin created by @JelteDeJong is probably the best option.
https://apps.autodesk.com/INVNTOR/en/Detail/Index?id=2268703737300536294
As for converting this to run with VBA, it could be done, but without digging into I don't know what all it would take.
I hope this helps.
Curtis
Sprocket1077
Hi Curtis_W.
Thank you very much for your help.
