Add to general note <MASS> parameter
Damian_Apex
Damian_Apex
I'm looking for a piece code in which I can give <MASS> parameter in general note on drawing.
This is my code to create general note on drawing and I want to create new general note little above it with <MASS> parameter
Sub main
Dim oAssemblyDoc As Inventor.AssemblyDocument
oAssemblyDoc = ThisApplication.ActiveDocument
Dim oDoc As Document
Dim Path As String = ThisDoc.Path & "\"
Dim SourceFileName As String = ThisDoc.FileName(True)
Dim oModelName As String = Path & SourceFileName
oDoc = ThisApplication.Documents.Open(oModelName, False)
Dim oDrgDoc As DrawingDocument
oDrgDoc = ThisApplication.Documents.Add(kDrawingDocumentObject, "C:\Work\iLogic\Templates\en-US" & "\" & "APEX TEMPLATE DWG.idw")
Dim oSheet As Sheet
oSheet = oDrgDoc.Sheets.Item(1)
AddNote(oSheet)
end sub
Public Sub AddNote(oSheet As Sheet)
SetNotePath = "C:\Work\Library\NOTES\FABRICATION NOTES DWG-A.F.S.txt"
Dim
oGeneralNotes As GeneralNotes
oGeneralNotes = oSheet.DrawingNotes.GeneralNotes
Dim
nTG As TransientGeometry nTG = ThisApplication.TransientGeometry
oRead
= System.IO.File.OpenText(SetNotePath)
EntireFile = oRead.ReadToEnd oRead.Close()
Dim sText As String sText = EntireFile
Dim
nBorder As Border nBorder = oSheet.Border
oGeneralNote
= oGeneralNotes.AddFitted(nTG.CreatePoint2d(nBorder.RangeBox.MaxPoint.X-10, nBorder.RangeBox.MaxPoint.Y-15), sText) 'Top Left below BOM
oGeneralNote.HorizontalJustification = kAlignTextLeft
End Sub
Ralf_Krieg
Hello
To add the MASS parameter, you need to edit the FormattedText Property of the GeneralNote. AFAIK it's not possible to create the note direct with this. I would try to create the note with a very simple text and replace the value of the FormattedText property right after with the string "WEIGHT PER 1 AS SHOWN (kg): <PhysicalProperty PhysicalPropertyID='72449' Precision='3'>MASS</PhysicalProperty><Br/>TOTAL 2 REQUIRED FOR 1 UNIT"
R. Krieg
RKW Solutions
www.rkw-solutions.com
