Add to/ Delete parameters from iLogic Form via Rule
TobFischer94
TobFischer94
depending on preferences, i can have a range from 1 to 50 parameters (named Y1, Y2, Y3... etc.) that i want to control via an iLogic Form. But i only want parameters that i really need, shown in my form. I know there is an option to "grey them out", but in my case it would be better to outright delete them or only add those that i need. It would be awesome if i could add the needed parameters to my form via a Rule, or if that is impossible, delete the parameters from my form that are not assigned.
Any ideas?
Thanks!
HermJan.Otterman
you can't
just set them to not visible.
if you whant to have more controll over your form, use a VB.net form and use that in your iLogic.
but then still you turn of the controlls
If this answers your question then please select "Accept as Solution"
Kudo's are also appreciated Smiley Wink
Succes on your project, and have a nice day
Herm Jan
