Add Radius Dimension iLogic
Hello everybody,
I am trying to add a Radius dimension with tolerance to a specific curve on a drawing.
Can anyone advise how I can select/get the curve as a GeometryIntent in order to add the dimension ?
oSheet.DrawingDimensions.GeneralDimensions.AddRadius(Point2d, My Curve as GeometryIntent)
 can I select the geometry by adding workpoints in the 3D model ? (center + 2 points) ? or is there a way to attribute a name to the curve in the 3D model and then import it to the drawing ?
Thanks in advance,
I found the solution by searching for drawing arcs that have the centerpoit equal to centerpoint of corresponding radius.
Dim oCurves As DrawingCurvesEnumerator = oView.DrawingCurves
For Each oC As DrawingCurve In oCurves
	If oC.CurveType = CurveTypeEnum.kCircularArcCurve Then
		If oC.CenterPoint.IsEqualTo(oCenter) Then
			Dim oInt As GeometryIntent = oSheet.CreateGeometryIntent(oC)
			oDim11 = oSheet.DrawingDimensions.GeneralDimensions.AddRadius(oPt_txt, oInt,,,,oNewStyle)
			Exit For
		End If
	End If
Next
